Neutral safety switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2007, 08:23 PM
Help!!! Cant find my book, need to adjust my neighbors 77 Chevy p/u, auto on the column. As I recall,the adjustment involved the use of a drill bit, similar to a Hurst adjustment. Any one out there know what I'm talking about?
Old 02-16-2007, 08:43 PM
poncho62's Avatar
Wiki Edits: 5
No I dont....I just loosen the 2 screws and move it until it works in "D" and "N".
Old 02-16-2007, 08:51 PM
fast68's Avatar
likes chevy trucks & boobies
there is a hole in it that you can stick a small bit or rod or whatever in, i would think you first loosen the switch up and put it in park or neutral most likely, and move the switch around until the rod or bit goes in the hole and then tighten up the screws
i bet ya
i have a couple of old pickup truck columns laying around here, if ya need i can try it out
good luck
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 01:35 PM
need help with neutral safety switch Grey1961 Electrical 5 12-12-2005 12:22 AM
? about my neutral safety switch in C10 Streetmaster Electrical 4 08-30-2005 02:41 AM
El Camino/ neutral safety switch stinky jinx Electrical 4 03-15-2005 11:00 PM
neutral safety switch zipfactor Electrical 2 08-30-2003 08:58 PM
