neutral safety switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2010, 11:01 PM
I have a Lokar floor shifter with neutral safety switch on a TH350 transmission
that allows the motor to start in park, neutral AND drive. All other gears the nss does not allow the motor to start. Drive is the only problem. Is the switch bad or is there some type of adjustment I need to make?
Thanks
Old 08-21-2010, 05:56 AM
poncho62's Avatar
Wiki Edits: 5
Not sure how its set up, but likely bolts to the side of the handle and you should be able to see where its making contact.......probably just needs adjusting
Old 08-21-2010, 11:10 AM
Nss
Thanks, Poncho!
Old 11-30-2010, 12:51 PM
99 camaro rs
hello my name is mike wher is the neutral safety switch on 98 camaro rs
Old 11-30-2010, 04:52 PM
EOD Guy's Avatar
on my Hurst, the micro switches are mounted in the side of the shifter, one is for the rev lights and the other is the NSS. twice mine has bounced out of adjustment.... a drop of lock-tite and it's been good since.
Old 11-30-2010, 05:42 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
You need to disconnect the linkage from the shifter to the transmission.
Using an ohmmeter to determine when the NSS is closed (to permit starting), move the shifter to the neutral position. The switch should be closed. Then move the shifter to the drive position. The switch should open but if the switch is still closed unscrew the switch from the shifter bracket just a small amount until the switch opens as indicated by the meter. Then move the shifter to neutral to see if the switch closes. If it does then this should be the position for the switch. Then put a washer on the switch threads to keep it in position. After this recheck the switching to see if the switch is closed in neutral and park and open in all the gears.
Install, adjust the shift linkage to the transmission.
vicrod
Old 11-30-2010, 06:29 PM
Neutray Safety Switch
Thanks, Vic, I appreciate the info.
Jim
neutral safety switch on a stick? chirpn69 Electrical 14 03-05-2007 04:30 AM
Ford C4 neutral safety switch 37fordslantback Electrical 1 02-27-2003 03:05 AM
neutral safety switch mgentry Electrical 1 01-01-2003 07:53 PM
Neutral Safety Switch NSS C4 Zamteam Electrical 2 12-27-2002 02:44 AM
Neutral safety switch help insomniac Electrical 10 10-10-2002 12:00 PM
