neutral safety switch on a stick? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2007, 03:04 PM
I know this is probably the dumbest question ever. Do manual trans. have a neutral safety switch? I'm going to the track for the first time on wed march 7th and Im going through the street class rules and it says neutral safety switch is mandatory. I have a 69 ss camaro with a Muncie 4speed. I know I am supposed to have a switch on the shift linkage for the reverse lights but never came across a neutral safety switch.
Old 03-04-2007, 03:28 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
With a manual trans you normally have a safety switch on the clutch. It has to be down for the car to start. No neutral safety.
Old 03-04-2007, 03:45 PM
the car will attempt to start(leap forward) in all gears without pressing the cluch pedal. Is there somthing im missing?
Old 03-04-2007, 03:59 PM
charley1's Avatar
hot rods forever
clutch
without the clutch engaged the car will roll when you crank the starter over pushing the flywheel in motion
Old 03-04-2007, 04:04 PM
weirdbeard's Avatar
1976 Ranchero GT
Yes there is a safety switch to keep the starter from turning the motor when the clutch is not depressed. It is there it keep the car from lurching forward if someone trys to start it while it is in gear.
Old 03-04-2007, 04:48 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Yes ...
It sounds like someone has by-passed that clutch safety switch that Weirdbeard was telling you about.
The engine should not crank without the clutch pedal pressed to the floor.
I tried to find a switch picture for you, but came up empty on Standard (Blue Streak), NAPA, and Autozone websites.
I DID finally find it! (I think.)
(I'm kind of a persistant son-of-a-gun partsman)
Apparently they used a
rod
to connect the clutch pedal TO the
switch
Old 03-04-2007, 05:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
After you locate the CSS, (look under the dash, at the front or rear of the clutch pedal travel) to insure it is correctly wired, There will be a wire coming from the Ignition switch, from the "Hot In Start Only" terminal, this wire will go to one side of the CSS, and only have power on it when the key is in "Start mode".
The other side of the switch will (Should) Only have power on it when the ignition switch is in "Start" only AND the Clutch is depressed..(or having a bad day.. ) This wire goes to the "S" terminal on the starter solenoid.
It is possible to have both, NSS and CSS, There a few aftermarket makers that have bolt on NSS for about any transmission. so you may want to look "down under also for an "Extra switch" not being used (usually on BU lamp switch as an extra pair of contacts , 4 instead of two) You really only need one..both is over kill but nice.
It may just be that the switch is out of adjustment, and something is jamming it on..or as mentioned somebody bypassed it not a safe environment.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-04-2007, 10:06 PM
Cars built prior to the late '60s only had the clutch safety switch that was located on top of the driver's neck. It generally worked well for the cars, maybe less so for some drivers. You do have to follow the proper starting sequence, but you'll learn it quickly.
Also, your engine will be happier if you start it in neutral with the clutch pedal out. Starting with the clutch disengaged is hard on the crankshaft thrust bearing.
And on the off chance that you might need to move the car out of harm's way real quick and the stinkin' engine won't start, you have the option.
Old 03-04-2007, 10:16 PM
dinger's Avatar
[QUOTE=jimfulco]Cars built prior to the late '60s only had the clutch safety switch that was located on top of the driver's neck. It generally worked well for the cars, maybe less so for some drivers. You do have to follow the proper starting sequence, but you'll learn it quickly.
QUOTE]
Just what I was thinking.
Old 03-04-2007, 10:29 PM
So Ive looked and there is not a switch on the clutch should I just assume that my 69 camaro did not have one. The only thing at the clutch pedal is a stop keeping the pedal from moving closer to the driver
Old 03-04-2007, 10:30 PM
66GMC's Avatar
LOL ... Well that SOUNDS good in theory, and it probably worked quite well before the days of litigation.
When was it, exactly, that people began to believe that they were not responsible for their own stupidity?
Seriously though ... Neutral Safety switches prevent a lot of pre-schoolers that don't know any better from running over their parents and siblings.
There are also stories in the paper every year about farmers getting killed by shorting across the starter solenoid of their tractor ... that they left in gear. When those things start up, you become an unsubstantial speed-bump.
Old 03-04-2007, 10:37 PM
66GMC's Avatar
No signs that it ever had one, either?
No dangling wire connectors, shiny spots or empty holes on the pedal arm?
Perhaps you could check with GM and see if they were optional?
I wonder when they became a requirement?
In any case, you could order the parts that I found for you in a previous post if this is a feature that you desire.
Old 03-04-2007, 10:45 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
My 56 ford does not have one. It will crank in any gear. You only do that once (just moved forward a bit)!
Old 03-04-2007, 11:06 PM
A '69 Camaro should have one. My '69 Nova does. It's under the dash, and it works directly off the pedal arm, no linkage involved. I'd expect a Camaro to be similar. I haven't seen one since about 1972, but I think there might have been a fat purple wire going to the connector.
Old 03-05-2007, 04:30 AM
Last journal entry: A few ongoing projects
I'm not sure whenthey became mandatory, my 68 El Camino doesn't have one, but I do recall haivng had to replace one on a 69 (?) or 70 several years ago. The switch will be connected thry a lavernder (purple) 12 or 10 guage wire.
Holley Safety Fuel Pressure Switch Wiring camaro80 Electrical 4 01-20-2006 09:02 PM
Ford C4 neutral safety switch 37fordslantback Electrical 1 02-27-2003 03:05 AM
neutral safety switch mgentry Electrical 1 01-01-2003 07:53 PM
Neutral Safety Switch NSS C4 Zamteam Electrical 2 12-27-2002 02:44 AM
Neutral safety switch help insomniac Electrical 10 10-10-2002 12:00 PM
