Neutral Safety Switch on TH-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 12:43 PM
Please correct me if I am wrong on this. It is my understanding that a Neutral Safety Switch is IN some TH-350 transmissions. If so, how is this switch wired? It only has one terminal. I have a floor shifter (Hurst Pro-Matic) that does not have an incorporated NSS. I would rather not buy a new shifter if a don't have to. Thanks.
Old 11-22-2007, 01:44 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you are incorrect. No switch in the t-350
The neutral switch was usually on the column if a column shifter.... on the floor shifter IF a OEM shifter is used
Old 11-22-2007, 01:54 PM
poncho62's Avatar
Wiki Edits: 5
If its a 69 Nova its under the column..........Even if its a floor shift, they had a linkage up to turn the piece on the column too..........All part of the key in the column incorporated that year. That's how my Chevelle was anyways.
Old 11-22-2007, 02:42 PM
31 five window
Last journal entry: grill and rear end
To the best of my knowledge that is a lock up converter terminal,TH350 never came with an internal neutral safety switch.
Old 11-22-2007, 03:40 PM
life is a temporary assignment
I think some are on the bottom side of the column,under the dash.not sure about your car. hope this helps.
Old 11-22-2007, 04:01 PM
Some early 70's Chevy/GMC vans with the Turbo 350 have the neutral start switch mounted ON the transmission. The case has two extended prongs cast into the left side of the case just above the shift lever.
Most column shifted GM's have the neutral start/back up light switch on the column. The column above is a GM van ... look and you can see the switch.
LOKAR makes a somewhat universal fit neutral start switch that should be fairly easy to adapt to your Turbo 350. It mounts to the transmission pan and has levers that work in cojunction with the shift lever coming out of the transmission.
Go here ...
http://www.lokar.com/product-descrip...ral-safety.htm
neutral safety switch on a stick? chirpn69 Electrical 14 03-05-2007 04:30 AM
Ford C4 neutral safety switch 37fordslantback Electrical 1 02-27-2003 03:05 AM
neutral safety switch mgentry Electrical 1 01-01-2003 07:53 PM
Neutral Safety Switch NSS C4 Zamteam Electrical 2 12-27-2002 02:44 AM
Neutral safety switch help insomniac Electrical 10 10-10-2002 12:00 PM
