Neutral Saftey switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2011, 02:16 PM
My 727 trans is a AMC version and has a a 3pin neutral saftey switch. Which is this hot or constant, and which is the ground. And the hot wire, does this go to the ignition switch, or remote starter solenoid, in order to turn the engine on? Sorry, wiring is not my strong suit by a mile!
Old 01-28-2011, 05:40 PM
LATECH's Avatar
I believe the center one is power. The two outside ones are for starter relay and one is backup lights.
Verify that with a test light, but i believe that is correct.
Old 01-28-2011, 06:27 PM
Ok gonna close this one and continue this on my other post. thanks.
Neutral Saftey Switch help.. APalusky Electrical 19 07-14-2010 07:12 AM
neutral switch? 3gencamaro Electrical 3 03-15-2010 05:53 PM
AMC tach, voltage meter and neutral saftey switch. Javelin360 Electrical 9 08-18-2007 03:50 PM
neutral switch theuntouchables Transmission - Rearend 9 07-03-2007 02:29 PM
neutral saftey switck cro77 Electrical 2 02-08-2007 01:39 PM
