neutral safty switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2004, 08:54 PM
armalite's Avatar
Hello all!
1st post here..
I have a few ????'s
I have a 2000 jeep wrangler that won't start with the clutch in and the key.
Acts like the clutch isn't depressed.
Just dead nothing!!!
Yet it will push start and run fine.
I looked under the dash for the safty switch but there isn't one. How do I find this thing to disable it, and get the jeep to start?
I posted this here since I figure this is a electrical problem since there is no manual push type system on the pedal it's self.
Thanks
Rich
Old 02-05-2004, 08:58 PM
Will it crank in Neutral ???
Old 02-05-2004, 09:00 PM
armalite's Avatar
nope it's the same with the clutch in or out. doesn't crank @ all.
Like I said it will pop start.
later
Rich
Old 02-05-2004, 09:41 PM
lust4speed's Avatar
Don't limit your search to just a neutral safety switch. It could also be anything from a bad key switch, bad solenoid, or loose wires to the starter.
Old 02-06-2004, 10:30 AM
armalite's Avatar
I bypassed the ignition
Started right right up. So now I think the ignition switch is bad.
Thanks for the help guys.
On a side note I can't find any mention of a NSS on any car forums nor with a search engine @ least for the 2000 wrangler. So I think it's probably electronic. Also when doing above the jeep started with out the clutch being pushed in.
later
Rich
PS:
Can't wait for the powertrain warrenty to expire (another 20K) so I can join the inliners club again.
Old 02-06-2004, 01:37 PM
poncho62's Avatar
Wiki Edits: 5
On one of my cars, the neutral switch is right on the side of the trans (its an automatic)
Yours might be on the clutch linkage or clutch cylinder, if hydraulic.
