neutral switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2007, 09:49 PM
neutral switch
need help. have a 86 olds with a turbo 400 trans and a bm mega shifter.the shifter was installed but never hooked up neutral safty switch, kinda lost on how to hook up and i need it for drag racing. Mods have been made key doesnt start car but has to be turned too the on position,then i turn switch on for power and push button to start. Can anyone help? also changing trans from 400 to 350 do i need different drive shaft and cross member. THANKS FOR ANY HELP
Old 06-30-2007, 06:55 AM
The tail sgaft on the 400 is longer then on the 350 so yes you will need to change drive shaft length. The neutral saftey switch is under the steering column on every chevy ive seen. Im not sure how to tell you to hook it up but i can tell you that the big fat purple wire is usually the main wire for the switch.
Old 06-30-2007, 07:19 AM
wildman1932's Avatar
Dave's hot Rod Shop
That post is correct. The neutral safety switch is lower on the column, kind of banana shaped, on the stock car. The after market switch is a micro switch that should come with the shifter. It will line up with park and neutral, in those positions it will allow current to go to the starter.
Old 06-30-2007, 08:52 AM
safty switch
micro switch is on shifter but what doe i wire it to,thats were iam lost?Thanks for the responses so far.
Old 06-30-2007, 09:29 AM
The wire that goes from your start button to the starter solenoid should go through the neutral safety switch.
Old 06-30-2007, 10:13 AM
Crosley's Avatar
Wiki Edits: 1659
the fellows are missing the fact you have a B&M shifter now. NHRA rules require a working neutral switch for the starter.
As the fellows mention the OEM location for neutral switch is on the column if a column shifter.
Since you use a remote / different start button for starting, you will need to wire that switch through the neutral switch on the shifter.
As for mounting the neutral switch on the B&M shifter ..... phootos would help. Does B&M have a pdf file on instructions at their web site??? I do not know.
good luck
Old 07-02-2007, 07:57 PM
mega shifter
most popular shifter and it doesnt come with the micro switch.LOOKED high and low for pics and know luck,will try and call them direct tommorow. Sir crosley thanks for your help,i think i have it figured out.Can be wiried to starter button.MAYBE nhra rules cant live with em cant live with out them
Old 07-03-2007, 02:13 PM
biggeazy-e's Avatar
I can snap a few pics, I'll go out now and try to get some, will definitely have them posted in a few
EDIT-
http://www.iroczone.com/projshifter01.htm
not sure how well this one will work(pdf file)
http://www.bmracing.com/media/products/pdf/10.pdf
Old 07-03-2007, 02:27 PM
biggeazy-e's Avatar
Old 07-03-2007, 02:29 PM
biggeazy-e's Avatar
microswitch
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 12:35 PM
neutral safety switch on a stick? chirpn69 Electrical 14 03-05-2007 04:30 AM
need help with neutral safety switch Grey1961 Electrical 5 12-11-2005 11:22 PM
? about my neutral safety switch in C10 Streetmaster Electrical 4 08-30-2005 01:41 AM
El Camino/ neutral safety switch stinky jinx Electrical 4 03-15-2005 10:00 PM
