Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Never had a choice before.
Old 09-10-2012, 02:24 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Fan should work either way..the critical piece is the shrouding and also look at how air is directed to the radiator for a good airflow..Shrouding can be easily fabricated from aluminum flashing material that can be found at the local building supply. use pop rivets or the body panel glue to assemble the shroud. Most aftermarket fans come with a generic kind of shroud/mount that can be incorporated.
Sam
