Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Never had a choice before.
Old 09-11-2012, 09:56 AM
BarryK's Avatar
BarryK BarryK is offline
Thank you guys, we will make a puller, now that I went to a short water pump and eliminating the clutch fan have more room in there then I have ever seen on a car and the original shroud is staying, so no problem there.
Since I put on the oil cooler and went to 0w30 mobil-1, cooling has never been an issue with this car, where before after I built the engine, if ran on expressway for an hour, when you hit a town, it never over heated but temp would climb 20-30 degrees, for first 15 minutes in city driving and then go back to normal.
Thanks for the advice.
