Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - never seen this before
  #32 (permalink)
Old 05-20-2012, 06:59 AM
GMCTRUCKS's Avatar
GMCTRUCKS GMCTRUCKS is offline
Make up a batch of this.
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results!
*They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.*
*Penetrating oil ..... Average load*
None ..................... 516 pounds
WD-40 ............. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench .. 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
*The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone*
*Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.*
