never seen this before - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-20-2012, 06:55 AM
Richiehd's Avatar
JS-70
Originally Posted by boatbob2
My Buddy, just had the plugs changed in his Ford pickup,had to jack up cab,the bill was $1600.00,had to heli-coil every plug hole,fords better idea.
The butcher that did that would have done better to follow the proper removal procedure. ie: start with a cold motor
  #32 (permalink)
Old 05-20-2012, 07:59 AM
GMCTRUCKS's Avatar
Make up a batch of this.
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results!
*They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.*
*Penetrating oil ..... Average load*
None ..................... 516 pounds
WD-40 ............. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench .. 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
*The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone*
*Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.*
  #33 (permalink)
Old 05-20-2012, 08:18 AM
kool kat's Avatar
atf/acetone
Im mixing some up today!
I guessing you cant put it in a plastic container though...
  #34 (permalink)
Old 07-25-2012, 10:07 PM
ford spark plugs
I do them and the best thing to do is run a really good fuel cleaner thru before and they come right out. Terra clean works the best.
  #35 (permalink)
Old 09-10-2012, 09:31 AM
If you never want to have that problem again every 25-30k pull them out and re install, i have the extractor from snap on it works great but this little tip will work wonders for you in the long run
  #36 (permalink)
Old 09-10-2012, 08:53 PM
Richiehd's Avatar
JS-70
Terra Clean, who makes that? never heard of it. I have SeaFoam available by me, same thing?
  #37 (permalink)
Old 10-10-2012, 06:48 PM
59RAMBLERSUPERWAGON's Avatar
Its the right tool if it works
Last journal entry: Bondo oh no!
Originally Posted by boothboy View Post
I don't suppose you considered just turning the truck upside down and shaking the b'jesus out of it?
Just trying to help.
BB
See I learn something new every day, I thought it was called a spark plug shield, but its actually called a b'Jesus! Thanks boothboy!
