Never strip the damper bolt again - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2010, 09:04 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I have seen post recently where some have tried to adjust valves/lifters and ended up stripping the damper bolt. The torque value was exceeded over coming the mechanical resistance of the engine; can turn the engine over with the plugs in.
Have a look at this tool have used it for years, a few examples lifer adjustments, distributer installation .
How to use; remove the 3 pulley bolts from the damper. The pulley will stay on because the damper bolt will hold it on. Place the tool on the face of the damper reinstall the bolts, and have at it.
enjoy:
http://www.jegs.com/i/Proform/778/66...oductId=748260
Old 11-12-2010, 10:11 PM
bentwings's Avatar
bentwings
I took one of these and cut the Ford ear off and smoothed it all up. I just left it in place untill I added the blower which has a 1/2 in drive in the blower hub.
Work great. No excuse for stripping the crank bolt.
Old 11-13-2010, 08:33 AM
pepi's Avatar
Also much easier then trying to use the flywheel and ring gear to get things lined up, forget about starter bumping.
I prefer to remove it when done, not sure it is a balanced piece. However that is just me, take no chances or prisoners.
Old 11-13-2010, 08:36 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yep that's a handy little tool everyone should have one in the tool box. JMO
Cole
Old 11-13-2010, 09:50 AM
Irelands child's Avatar
Wouldn't it just be cheaper and easier to pull the spark plugs and relieve the compression?
Twenty two bucks plus ten shipping - that will take me and my wife to a fairly nice evening out or maybe put 10 gallons of gas in my car or purchase a bottle of John Jameson's uisce beatha
Dave W
Irelands child
Old 11-13-2010, 06:57 PM
bentwings's Avatar
bentwings
With better than 12k miles on my SBC you still would probably strip the puny crank bolt even with the plugs out. Plus with one of these you can turn the motor either way. I also use it to run leak down tests, turn the motor over to check converter bolts.
Why not just make one...then you can still take the wife out to a cheap dinner......$32 doesn't buy much in this town. haha. Heck a good rod run costs more than $30 per each. haha
Old 11-13-2010, 07:49 PM
OH CRS - I forgot - SB Chebbies use 7/16" stove bolts for damper bolts, not the 5/8" that SB Fords use. No wonder the Chebbie bolts strip
Irelands child
Old 11-14-2010, 06:49 AM
pepi's Avatar
Good point, those fords sure are better cause they use big bolts. But this was not a thread about my bolt is bigger then yours.
I will say this we are not taking the front on the motor apart to fix plastic crap ........ are we ?
Yours running or is it still on jacks ?
many happy clown faces below
Old 11-14-2010, 07:15 AM
Pepi - Why are you so possessed by what I say - sad
Now - if you DO NOT understand a joke, it's even sadder
...and as far as my car, I'm sure you must be subscribed to my post and have watched carefully, making sure I made some more errors since I'm not quite as perfect as you.
A link to what for others to know what errors I made that Pepi is referring to: I had a bad day Saturday
Irelands child
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
help removing rounded off damper bolt? stroker444 Engine 9 05-17-2010 09:15 PM
Build a 10 bolt or 12 bolt for 450 HP ?? Blownchevelle68 Transmission - Rearend 7 05-11-2010 09:34 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 09:02 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 05:48 PM
