new 12 bolt rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2006, 07:36 PM
new 12 bolt rear
i just got my rear end for my 67 beaumont (chevelle) im ready to put the axles in its a moser rear end with posi 373gears in it with 33 splines for axels what kind of rear end fluid and do i have to add an additive for the posi please help me out.
Old 04-16-2006, 07:53 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
If you are breaking-in a new ring and pinion use the gear manufacturer's recommendation for break-in. I always use synthetic differential lube 100% in everything. Use a good posi-additive as recommended. The slightly inceased expense is irrelavent compared to what you just spent.
Old 04-16-2006, 08:23 PM
302 Z28's Avatar
Most high quality synthetic gear lubes already have the friction modifier in them so additional additives are redundant.
Vince
12 bolt rear end id help jimgto Transmission - Rearend 3 01-03-2006 06:38 PM
12 bolt rear id jimgto Introduce Yourself 2 12-26-2005 07:36 PM
12 bolt with 10 bolt carrier? JamesRS Transmission - Rearend 3 01-17-2005 08:59 PM
New 12 bolt Rear/ questions. RObs71Nova Transmission - Rearend 1 12-27-2004 07:19 AM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
