new 1940 chev pickup project - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #16 (permalink)
Old 12-13-2012, 06:27 AM
Wiki Edits: 27
welder Series info
Welder series in canada sells weld it your self hot rod and suspension parts and complete kits. They have lots of U tube video's and very good information on how to Install the M II suspension in their catalog and on line. I have a milling machine, lathe, Plasma, welders, etc and fab most of my own parts but there are some things that are easier and cheaper to buy considering the time to engineer and cut .
  #17 (permalink)
Old 12-13-2012, 07:18 AM
totally agree. there are lots of 8.8's in the wreckers. just a note of caution though. it has been said, not by me but by some knowledgeable differential builders online, that problems can be encountered with high horsepower engines using wrecker axles in this sort of configuration. they say that the axles get a "set" rotationally, and when they are installed in the wrong side, like when you use one from a wrecker that came out of the other side of the vehicle compared to what it will be placed into, they tend to break under high load. I have never heard of it, but then i don't travel in those high horsepower circles either. just a note for consideration. worse case scenario, buy a new aftermarket axle for that side.
  #18 (permalink)
Old 12-13-2012, 07:23 AM
I have some welders series stuff in the rear of my '57. it is really nicely patterned, cut and welded. you can save a few bucks by doing your own welding if you want. delivery is 10% of the cost of the item up to a maximum (to calgary anyway, not sure of out of country stuff). I would highly recommend them. check out the online catalogue. I had some questions and they got back to me right away by phone. i was impressed.
  #19 (permalink)
Old 12-13-2012, 07:31 AM
yea the guy we bought the first rear from didnt realize it was a 7.5 (niether did we until we looked at it the next day with some light) and he has a ton of mustang parts and we have been waiting for the next rear but we couldn't get a hold of him for a while ... finally he called the other day said his mom died and he we get the other to us by this weekend ... i have been keeping my eye out for 93-01 explorer as well as the width is close enough and they have the 31 spline 5lugs but i think 3.73 will be to high for a nice cruiser
  #20 (permalink)
Old 12-13-2012, 07:36 AM
Wiki Edits: 27
explorer rear
the V 8 explorers are stronger, the best one for higher horsepower and have the internal drum emergency brake design, a better brake , just a little longer to do a brake job.
  #21 (permalink)
Old 12-13-2012, 08:36 AM
if the rear end that is supposed to be hear today or tomorrow doesnt pan out that will be the one we with
  #22 (permalink)
Old 12-17-2012, 08:14 AM
well we got a little more work done this weekend got the front end mostly asembeled and removed the back fenders and box and rear end ... might have to exchange our spindles for the drop spindles to get a little closer to the ground as we are a bit higher right now than we would like but we have the dummy motor sitting in the front right now and we cut a loop out of the springs that plus the weight from the transmission fluids water pump radiator alt.... should sit an inch or two lower than it is now so we will see
Name:	front end unpainted.jpg
ID:	69856   Click image for larger version
  #23 (permalink)
Old 12-17-2012, 08:31 AM
life is a temporary assignment
Looking very nice..
  #24 (permalink)
Old 12-20-2012, 09:46 AM
update we got the motor mounts welded in and have the rear end in position now we are waiting on the bars and konis to come for the 4 link and the rear that we are going to use... all the running gear that is in the truck currently a just for mock up
Name:	motor mounts.jpg
ID:	69937   Click image for larger version
Name:	trans mockup.jpg
ID:	69938   Click image for larger version
Name:	rear mock up.jpg
  #25 (permalink)
Old 01-02-2013, 07:43 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Looking good Barber,a 40 chevy one of my favorites ,, front independent looks good with coil overs,are you leaving efi or going carb ,What no 9 " LOL
  #26 (permalink)
Old 01-03-2013, 07:07 AM
750 edlebrock carb going on just as it had when the motor was dynoed ... 431hp & 458tq by the time it gets to the wheels probably 350-375 which the 8.8 can handle no problem plus the 8.8 was easier to find and less expensive and has the "ears" on it already for the triangulated four link that we want to run
  #27 (permalink)
Old 01-09-2013, 07:17 AM
between snowmobiling, the holidays, waiting on parts and what not progress has slowed a little but we got started on the 4 link and started on the seat.... also has anyone switch out hinges for the doors on their rod? ours are not in good shape looks like they have just been blasted with crap for years, i was thinking to doo sucide doors with poppers but have never done anything like this and wouldn't know what kit to use as for the hinges the shaving and popper wouldnt be an issue but the hinges have me concerned
Name:	4link crossmember.jpg
ID:	70418   Click image for larger version
Name:	4link welding.jpg
ID:	70419   Click image for larger version
ID:	70420   Click image for larger version
Name:	old door hinge.jpg
  #28 (permalink)
Old 01-15-2013, 06:32 AM
updates 4 link completed and painted, frontend painted, now moving to the inside for a while got the steering colum in place and have begun modifying the floor pan for the t400
Name:	4link painted.jpg
ID:	70613   Click image for larger version
Name:	back shot of konis.jpg
ID:	70614   Click image for larger version
Name:	front end painted.jpg
ID:	70615   Click image for larger version
Name:	floor pan start.jpg
  #29 (permalink)
Old 01-18-2013, 01:01 PM
well getting closer to painting the engine bay and we are really tryign to decide on the color scheme for the truck here is a pick of what we are leaning towards what do you guys think and feel free to post pics of other color schemes that you think would look good on a 40s pickup
*** this is a long shot but if anyone knows where i can find more pictures of this truck or any more info on this truck in the picture please share as there are a few things with this truck i would like to know thanks.
  #30 (permalink)
Old 01-18-2013, 06:25 PM
Built Not Bought
some poeple on trivia site were reverse postin some way to tell where piocture was tahen and where posted i dont know how they do it ,they might help
1940 chev pickup rearend barberboys Transmission - Rearend 6 11-27-2012 08:32 AM
1940 Ford Pickup TNMEngr Introduce Yourself 1 05-06-2009 04:34 AM
1940 Chev Chassis GCD1962 Hotrodders' Lounge 1 12-14-2007 09:17 PM
Source for 1940 Chev fenders Tim240Z Body - Exterior 2 06-14-2004 06:49 PM
Oh No!! 'nother Newb! w/? on 1940 chev Tim240Z General Rodding Tech 15 05-20-2004 10:42 AM
