Originally Posted by 427HISS
It's not a issue. I have the lb. concrete torque specs somewhere and I'll post all the information for you. My friend with the mechanic shop has the industrial size two post/four arm lift's and he has never had a problem. And he lift's all kinds of vehicles from econo box's, 1 ton trucks and over.....
Thanks
Actually, it is an issue as every lift manufacturer that I'm aware of warns about loose anchors and gives minimum specs for the concrete in both thickness and PSI. I've seen a lot of residential garages with 3 1/2" thick poured slabs and nothing but welded wire reinforcement.
Please make certain your concrete meets at least the minimum standards recommended by the lift manufacturer. Also, take note of the warnings about loose anchors, 'wallowed' holes, shimming to plumb the posts, and minimum distance from cracks or expansion joints.
