-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   New 2 stage pump to replace a single stage pump. (http://www.hotrodders.com/forum/new-2-stage-pump-replace-single-stage-pump-225039.html)
chief36chevy 10-15-2012 10:01 PM
I have an older 5 hp campbill hansfield single stage compresser that won't keep up with my air tools. I can get a replacement 2 stage pump that i can mount on my compresser for about $500.
My question is would it be worth my while?
OneMoreTime 10-16-2012 01:38 PM
If your tank and motor are in good condition go for it..We replace pumps on compressors in industry on a regular basis..Check the motor rating to see if it will run the new pump..
Sam
chief36chevy 10-17-2012 10:14 AM
Clarify
Sorry! What I meant to ask is how I can tell if the motor is a 5 hp.
No ware on the data plate does it say 5 hp, but it does have a sticker on the end that says 5 ph.
It is a Century motor with a 15 amp draw. I have read many articles on this subject and I am now even more confused.
:confused:
JohnnyK81 10-17-2012 10:24 AM
15 amp is not 5 horsepower.
15 amp at 220 can produce approx 2640 watts using approx 80 eff. That is 3.5 horsepower.
Old Fool 10-19-2012 07:13 PM
Ask for the manufacturers rpm recommendation for a 3hp motor then use the proper pulley to achieve that rpm.
hduff 11-04-2012 01:37 PM
Where did you get/are you getting the pump? I'm looking for one with similar ratings.
chief36chevy 11-06-2012 03:59 PM
I was looking at Surplus Center.
They have an 18.25 CFM AIR COMPRESSOR TWO STAGE 5 HP for $448.95 and the shipping was not that bad.
But since then I was able to pick up a 5hp motor, 5 hp 2 stage compressor and a 60 gal tank off eBay. The guy was only about 60 miles away and everything is like new. He said that he started to build an air compressor about 8 years ago and this was all the further he got.
I needed a motor pulley, belt, pressure switch, and in tank check valve I got them from Surplus Center. Shipping is not bad both price and time.
