New 2 stage pump to replace a single stage pump. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2012, 09:01 PM
chief36chevy's Avatar
Last journal entry: Front sway bar cont.
I have an older 5 hp campbill hansfield single stage compresser that won't keep up with my air tools. I can get a replacement 2 stage pump that i can mount on my compresser for about $500.
My question is would it be worth my while?
Old 10-16-2012, 12:38 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If your tank and motor are in good condition go for it..We replace pumps on compressors in industry on a regular basis..Check the motor rating to see if it will run the new pump..
Sam
Old 10-17-2012, 09:14 AM
Clarify
Sorry! What I meant to ask is how I can tell if the motor is a 5 hp.
No ware on the data plate does it say 5 hp, but it does have a sticker on the end that says 5 ph.
It is a Century motor with a 15 amp draw. I have read many articles on this subject and I am now even more confused.
Old 10-17-2012, 09:24 AM
15 amp is not 5 horsepower.
15 amp at 220 can produce approx 2640 watts using approx 80 eff. That is 3.5 horsepower.
Old 10-19-2012, 06:13 PM
Ask for the manufacturers rpm recommendation for a 3hp motor then use the proper pulley to achieve that rpm.
Old 11-04-2012, 12:37 PM
hduff's Avatar
Last journal entry: Still no real progress
Where did you get/are you getting the pump? I'm looking for one with similar ratings.
Old 11-06-2012, 02:59 PM
I was looking at Surplus Center.
They have an 18.25 CFM AIR COMPRESSOR TWO STAGE 5 HP for $448.95 and the shipping was not that bad.
But since then I was able to pick up a 5hp motor, 5 hp 2 stage compressor and a 60 gal tank off eBay. The guy was only about 60 miles away and everything is like new. He said that he started to build an air compressor about 8 years ago and this was all the further he got.
I needed a motor pulley, belt, pressure switch, and in tank check valve I got them from Surplus Center. Shipping is not bad both price and time.
Single stage vs Two Stage vs 50% base/clear a1960apache Body - Exterior 51 09-19-2010 06:16 AM
Is it possible to match single stage colors to 2 stage colors? STATUTORY GRAPE Body - Exterior 6 02-05-2006 11:32 AM
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 06:33 PM
single stage or used 2 stage? zimaad Garage - Tools 9 08-04-2005 08:19 PM
bc/cc over single stage? Lay'nFrame Body - Exterior 1 06-04-2003 01:56 PM
