new 350 chevy startup!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2007, 11:26 PM
chevymastermind's Avatar
drive it like you stole it!
Last journal entry: engine
hi everyone i am currently turning over my brand new 350 380HP motor that i built thats in my nova. it goes from the fuel cell to a new fuel filter (summit racing) to the front of the car the a HP Holly fuel pump up through a very small filter to the 2 feed lines of the Holly 650 double pumper.
how much cranking time should it take to get the gas from the fuel cell to the motor (carburator) through -6AN steel braided lines?
thank you in advance!!!
Old 06-02-2007, 11:31 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Gravity and the weight of the fuel in the tank should bring the fuel to the pump on the engine. You could break a fitting at the inlet of the pump and see if there's fuel there. From there the pump should supply the carb with fuel fairly quickly. You could pour some fuel down the bowl vents to get it started.
Old 06-02-2007, 11:33 PM
well i got a 22 gallon top sipping fuel cell in the trunk supplying the fuel. so it needs to be sucked up and through. sorry i didnt mention that!!!
Old 06-03-2007, 09:29 AM
Blazin72's Avatar
Wiki Edits: 19
The pickup for the fuel should still be down near the bottom of the tank. 22 gallons of fuel should be enough weight to push the fuel through the line.
Old 06-03-2007, 06:22 PM
Get a plastic squeeze bottle(catsup or mustard bottle) and fil the carb through the vent tubes, this will motor started right away and get tehe fuel to the pump also. You want to do everything you can to get the engine to fire on the first couple times it turns, fuel in the carb, timing as close as possible etc.
Old 06-04-2007, 09:39 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
you could just drop a few teaspoons worth of gas down the carb to get it to fire a bit, then the pump should get going enough to fill the carb. Or even better put some gas in the carb bowl!
Old 06-04-2007, 05:09 PM
techinspector1's Avatar
Wiki Edits: 326
Exactly right. Everything needs to be ready to go. Minimal grinding on the starter and zero idling time for 20 minutes. The lobes and lifter crowns are lubed by splash off the crank. If the crank isn't turning fast enough to provide splash lube, the lifter crowns will go south on you.
This is assuming a flat tappet cam. If you're using roller lifters, just fire the motor and drive it. No break-in required.
Old 06-04-2007, 07:38 PM
XNTRCI-T's Avatar
AKA Lee in KC
Enough said!
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 10:41 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
