new 350 clatters when cold - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2010, 10:47 PM
jls4speed's Avatar
simply put. i can start the motor and rev it and is super smooth. but, when i start it on a cold day, or lets say until it reaches operating pressure i hear a knocking. especially when its shifting from first to second. it seems to me like its the lifters. as i throttle through first gear and start hitting 2500 rpm i can hear a sound like if you were to repeatadley tap a marble against an anvil as fast as you could. as i reach the top of first ger its the worst. hits second and i dont hear it. idk. any ideas? once warm, it goes away. new lifters and cam by the way. month old.
Old 11-09-2010, 10:52 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Could it be detonation?
Old 11-09-2010, 10:59 PM
jls4speed's Avatar
no way. ive had detonation and previous motors and i could NEVER mistake that sound.
Old 11-10-2010, 12:17 AM
DoubleVision's Avatar
Sounds like piston slap to me. Before I rebuilt my 4.3 V6 in the winter months cold start you could hear a couple of pistons slapping under load. Sitting at idle you didn`t hear it. Once it got up to temp the slap went away. Hyper pistons which don`t expand much and call for very tight cylinder tolerances are prone to piston slap even if the clearance is only slightly too big.
Old 11-10-2010, 12:20 AM
Semper Gumby
Wiki Edits: 2
350 clatter
If it ONLY rattles when the engine is cold, it may well be that the oil isn't getting "upstairs" fast enough. What oil are you using? I used to have a 350 -powered pick-up that seemed to prefer to have 20-50 oil rather than 10-30 or 10-40, but would give me lifter rattle until it began to warm up. Didn't do that on 10-30. (I eventually settled on a half&half mix of 10-30 and 20-50. Engine was happy hot or cold.
Old 11-10-2010, 12:25 AM
jls4speed's Avatar
im runnin 10w 40. it doesnt burn oil or anything. if i run 20/50 will i kill my motor?
Old 11-10-2010, 12:53 AM
Semper Gumby
Wiki Edits: 2
Clatter
Not likely to kill it if you put 20-50 in it - but it will take even longer for the oil to start going through the lifters and you will spend even more time listening to the rattle.
Sometimes something as simple the oil filter type has a bearing on this too.
Since you say this is a "new lifters & cam" situation, there could be issues with clearances, too. Too loose or too tight in some areas can cause either not enough oil to get through, or too much to by-pass and cause the lifters to rattle until things warm up a bit. Is it maybe ONE lifter or all of them?
A few things to ponder.
In my case the reason my engine liked the 20-W50 was because it was getting old & tired and yet I needed it to pull some fairly heavy trailers and it would burn oil if I used too light a grade. Yet the 20-50 was too heavy on first start in the morning and caused the lifter clatter. The 50/50 mix of 10-W30 with 20W50 was a stop-gap solution that worked! (for me, for that engine, under those conditions, etc)
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Centrifugal advance DENCOUCH Engine 7 05-07-2010 07:39 PM
350 chevy wont cold start J. E. Allison Engine 8 02-18-2010 07:59 PM
Oh crap!! 350 or 327?? Biscuit6447 Engine 19 08-28-2009 12:59 PM
Cold run/fuel enrichment for '94 Chev 350? FlyB58 Engine 4 01-04-2003 08:54 AM
