New 350 sbc build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-05-2010, 10:23 AM
DoubleVision's Avatar
Too big? I doubt it. 2.5 inch dual pipe is the common size almost any exhaust shop will use on a 350 chevy stock or modified. I would only run a single 3 inch pipe if there wasn`t enough room to run duals.
Some systems don`t sound good with certain mufflers unless a balance pipe is added.
Stfinney, one thing you can do to find where the balance pipe should be is by spray painting a narrow line on the exhaust pipe after the header. Take it down the road for about 5 miles and get on it hard a few times. Let it cool and look at the pipe, where the paint is bubbled or missing will be the hottest place on the exhaust, this is where you should add the balance pipe.
  #17 (permalink)
Old 08-05-2010, 11:03 AM
this is basically a stock engine and a single exhaust will provide better low end.
2.5" is about the smallest a shop will usually install, I just think that it is the wrong way to go if you're looking for torque with a basically stock engine.
  #18 (permalink)
Old 08-05-2010, 01:07 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by DoubleVision
... one thing you can do to find where the balance pipe should be is by spray painting a narrow line on the exhaust pipe after the header. Take it down the road for about 5 miles and get on it hard a few times. Let it cool and look at the pipe, where the paint is bubbled or missing will be the hottest place on the exhaust, this is where you should add the balance pipe.
X2, this WORKS,
For a STOCK motor, I'd go 2" or 2/14", if it's even slightly modified, 2 1/2" will be fine, maybe drop to 2 1/4" for the tailpipes, to keep the velocity up as the gasses cool and contract,
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
350 SBC Build / considering Roller ROckers - what Ratio? early68 Engine 13 07-23-2010 02:05 PM
fresh sbc 350 build 400 hp poss? jasont/a83 Engine 28 05-03-2009 09:21 PM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
