new 383 maiden voyage..tuning help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2010, 08:37 PM
Made it down the road for the first time in 6 yrs Saturday! My first 383 sbc build seems good so far. It runs nice and cool at about 35mph or higher, but wants to heat right up at a stop sign. The 16" Derale fan is not enough. Has anyone tried the Chevy HHR fan set up yet? I hear its great and cheap? Also, does anyone out there have any baseline tips for me to make sure Im not to lean/rich? I have a lunati "268" cam with trick flow heads and 10.5 -1 compression. My Holley 700 has 72/78 jets with a 4.5 pv. I set the initial timing at 10 and the full advance is 35.
Old 05-31-2010, 09:18 PM
Do you have a vacuum advance hooked to manifold vacuum it will help cool it down.. Try more timing approx 3 degrees.
Old 05-31-2010, 10:21 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Sounds like your fan shroud either wasnt installed or isnt doing its job.
K
Old 06-01-2010, 08:53 PM
sdluck,
I have a Mallory unilite dizzy that has a fixed mechanical advance. Its all in by 3000, but if I advance by 3 deg, the initial will be about 13. You think thats ok?
383 driving me crazy, help with tuning issues (Holley Street Avenger) JLeatherman Engine 41 12-01-2009 09:31 PM
pcm tuning anyone 383 vortec efi ? 383silverado Engine 17 07-17-2009 02:50 PM
Weird 383 Tuning Problem mupton Engine 5 10-28-2007 08:21 AM
383 tuning novatech Engine 5 07-14-2005 10:23 PM
maiden voyage Bad Rat Hotrodders' Lounge 2 11-11-2004 06:26 PM
