new 396 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 03:06 PM
new 396
I have a 1971 Firebird with a fresh Chevy BB 396 engine. I want to test run it asap. Can I do this without the alternator hooked up? The engine wiring, electric fuel pump, battery, and HEI are all hooked up. The alternator is hooked up, but I need to do the rest of the dash/lights wiring. I want to run this thing first to make sure it is OK before I proceed. Is there some kinda diagram for this? I've seen many pictures of engines on 'dynos' and I dont see an alternator on most of them....How can I do this at home, in my garage, with the engine in the car???
Old 03-16-2012, 03:38 PM
6426yy's Avatar
You can do it with out but I'd leave a battery charger hooked up. Is it a flat tappet cam? Basically all you need is a wire from the post on alt to positive terminal on battery or to starter and one wire from the plug pigtailed to the post on alt. It's the outside one If I remember correctly. you could probably google it.
