New 7.5 hp Compressor. What breaker and wire size?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2011, 05:33 PM
roger1's Avatar
I just bought an Ingersoll Rand 2475N7.5 compressor today at Tractor Supply. It's a single phase 7.5hp motor.
http://www.tractorsupply.com/ingerso...ressor-3452272
I can't find anything in the instructions that says what breaker and wire size to use. I figure I'll need 35 feet of wire to connect to the main panel.
I saw one web site say that this is a 40 Amp unit but that is all I can find.
I'm figuring I need #8 or #6 wire but don't know if a 40 Amp breaker is enough or if I need a 50 or even bigger.
Don't know why they are not giving me more information to help me out with this.
Advice will be appreciated.
Addition:
Sticker on motors says:
Made for Ingersoll Rand by Weg IR part# 23172604
1 PH 208-230V
34 00-32 00 A
Does that mean 34 Amps start and 32 continuous??
If that's right then it would be 40 Amp breaker and #8 wire, right?
Old 12-29-2011, 07:18 PM
streetbruiser's Avatar
I'm assuming 220v not 110 right? 10 gauge wire is all that is needed for 220v and a 2 pole 40 amp breaker.
Old 12-29-2011, 07:45 PM
EOD Guy's Avatar
10 will work , But I used 8 because I also use the extension cord for the compressor to run my gen set with the pwr goes out. I have two cords 50 foot each, that I use to run the gen set..... they double as the pwr in for my welder and and air compressor.
I also used two 20 amp breakers to pwr the compressor etc...... works fine.
Old 12-29-2011, 07:46 PM
Addition:
1 PH 208-230V
34 00-32 00 A
40 amp breaker and #8. Dont use #10 on a 40 amp breaker!
Old 12-30-2011, 01:58 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The voltages on the nameplate 208/230 V are voltages commonly used in the US.
The ampere ratings on the nameplate are the full load ampere (FLA) ratings 34/32 A respectively for the motor.
The NEC (code) requires that the table 430.238 be used to determine the wire and breaker sizes.
For a 7.5 hp 1 ph 230 volt motor 40 amps is listed in the table.
A load factor is then applied to the 40 amps. 40 X 1.25 = 50 amps. Per table 310.16 - #6 wire is required.
A minimum (nominal) breaker is also 50 amps but can be increased to a maximum size of 100 amps.
For the purposes of the compressor a 60 amp breaker should be used.
vicrod
Old 12-30-2011, 02:04 PM
roger1's Avatar
Thanks Vic.
I already bought my stuff this morning. I bought 35 feet of #6/2 Romex, 4 ft of #6/2 S/O and a 60 Amp disconnect box. (I'll use the S/O from the disconnect to the compressor.
I bought a 50 Amp breaker however. Am OK with that as long as is doesn't pop? At least it is easy to change if I have to go to a 60 Amp.
Roger
Old 12-30-2011, 02:34 PM
vicrod's Avatar
life is a ride
That should be good.
The disconnect is a must for safety.
vicrod
Old 12-30-2011, 02:41 PM
Air comp
FYI. # 10 30 amps, #8 40 amps, #6 60 amps. I would put it on a 50 amp breaker and use # 6wire.
Old 12-31-2011, 06:14 AM
Roger, I have the same compressor (part number with Baldor motor) and use 10-2 wire with a 50 ft run, protected by a 50 amp breaker. This was recommended by a professional electrician and supported by a local electrical motor repairman. Have not had any problems since installed and the compressor has been used at least 5 days a week. Your larger wire is over kill, but will never hurt. It gives you room for expanding other circuits in your shop in the future, if desired.
Trees
Old 12-31-2011, 12:55 PM
roger1's Avatar
Trees
Trees,
I really don't understand how an electrician could have recommended that. That definitely does not meet code for a 7.5 HP motor that draws over 30 amps.
I think you need to do some more checking. I think what you are doing could be dangerous.
Old 12-31-2011, 12:56 PM
roger1's Avatar
Got air!!!!
Up and running just 30 minutes ago.
Man this compressor is quiet compared to my old one. That was a pleasant surprise.
Thanks for all the help guys!!!!!
Control box:
Old 12-31-2011, 01:51 PM
T-bucket23's Avatar
Wiki Edits: 26
Trees
10 Wire is much to small for a 50 amp breaker. The wire may burn up before the breaker pops.
Chet
Old 12-31-2011, 07:36 PM
EOD Guy's Avatar
Nice looking install
Old 12-31-2011, 08:22 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
This is very accurate information here, and needs to be heeded. Also, I might add, that 14 awg is 15 amps max, and 12 awg is 20 amps max.
Old 12-31-2011, 08:46 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
you are not done!!
there is not an easy to get at water drain on the bottom of that tank
it needs a 90 degree elbow screwed into the bottom with a 6" - 8" nipple and a ball valve sticking out, where you can get at it easy
60 amp circuit breaker and #10 ga. wire recommended??? HotRodMan Garage - Tools 9 01-24-2011 08:55 AM
welder fuse panel breaker size? jss Garage - Tools 35 11-07-2010 05:54 AM
air compressor size miamipops Garage - Tools 1 04-27-2010 07:17 AM
84 Cutlass, Chevy 383, How to wire a/c compressor labreejr Electrical 15 12-09-2008 11:56 PM
How to wire a 2 stage air compressor ? SCHOONER Garage - Tools 23 06-25-2007 01:46 PM
