?NEW 700r. squeals in reverse/but not low speeds? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2013, 09:25 AM
bsa_bob2's Avatar
I had a problem with the po squashing the pump /while "setting" the TC. to get the trans up tight to the engine.I had a Guy put a pump [used] but good he said. this trans works flawlessly as it is. So i get this all the time"don't back up fast and you won't hear it" This should be repaired! this trans was big bucks to the po.Any ideas are read! and welcomed thanks bob s
700r losing reverse as warms up noobasaurus Transmission - Rearend 6 01-31-2013 12:28 AM
Belt squeals 1969chevyss Hotrodding Basics 7 07-18-2012 10:56 AM
700r shutter in overdrive at low speed/rpm silver442 Transmission - Rearend 2 06-30-2011 08:50 AM
Need some 700R Speed-O Info S10Fan Transmission - Rearend 6 10-01-2009 06:35 PM
No Reverse..ford truck 5 speed transmition MAYNARDTRUCKIN Transmission - Rearend 1 07-17-2007 08:17 PM
