"New 700r4 blown in less than 30 mins" Pt.II - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2003, 09:35 PM
New Member
Ok, I've got a question about the 700r4's shifting characteristics under little to no throttle. If any of you read my post "New 700r4 blown in less than 30 mins", you already know what I've been through. Anyhow, I've got the second transmission installed, took it for the first road test and I can't tell if it is shifting normally or if it is stack shifting. Just to get it out of the way, the TV cable is set and I have double checked it by pulling the pan and checking pressure in all ranges. When I take off in OD with almost no throttle (I have to because I live in a pretty uppity yuppy neighborhood) it hits 3rd before I even get up to 25 mph. I know this probably seems to be a ******* question, yet while I consider myself to be quite mechanically capable, I have almost no experience with AOD transmissions. Could this be normal?
Old 10-18-2003, 12:53 AM
depending on the rear end gear you have and how easy on the throttle you are its possable.
Can you give any more details?
Old 10-18-2003, 05:54 AM
malc's Avatar
Living At The Speed Of Life
Even if you drive off in OD the trans, being an auto it will start off in first and shift up.Usually it chooses the gear for the speed of the car, mine shifts hard from 1st to 2nd and to 3rd but you hardly notice when it goes into overdrive.
Sorry to hear you still have problems,a new trans should be a bolt in solution.
Did you swap in the original govenor from the old trans?
Old 10-18-2003, 01:49 PM
airworld2's Avatar
700 question
same trouble??? adjust the cable to a bit more tension, should make shifts occur later.
airworld2
Old 10-18-2003, 03:55 PM
302 Z28's Avatar
I think with as much as you have been through, I would take the car to a reputable transmission shop. Let them drive the car and see what they think. It would be worth the price of a test driveif they charge you.
Vince
Old 10-19-2003, 01:46 AM
malc's Avatar
How exactly do you set your TV cable?
At the carb end I push the tab down and slide the cable back into
itīs retainer.Then I manually open the carb to full throttle,it will,if it needs it,pull the "right"amount of cable out of the retainer.
You can then adjust a few clicks up or down.Thatīs how the book says to do it.
Failing that I agree you take it to a shop for a test run.
Old 10-19-2003, 06:55 AM
adtkart@aol.com
If you have made any modifications to the vehicle/engine, I recommend that you verify that the gas pedal does open the throttle all the way. I have seen many times when the cable was adjusted improperly because it was adjusted by opening the throttle all the way at the carb, when the pedal wouldn't make it that far.
Then if adjusting doesn't work, take it to a shop.
Just a suggestion.
Old 10-19-2003, 10:31 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool absoloootly
check what atdkart says..... for full throttle function first.
I had a new customer come to me through a friend years ago.
his 70 chev truck had been to some high zoot guys in the Phoenix area. One is very well known for EFI performance developement stuff.
They ALL over looked the reason the truck did not perform well was the throttle only opened the carb 1/2 from idle.
I built a new throttle cable bracket, corrected some 700R4 tranny problems and his truck was screaming fast. The customer took the truck on a test drive,,,,, all I heard was tire rubber .
The customer had a huge grin on his face... made my day.
Old 10-19-2003, 12:22 PM
New Member
Thanks for the replies guys. I adjusted the cable out a couple of clicks and everything "SEEMS" to be correct now. My main problem is that I've got that memory in my mind od the first one breaking so I'm MAJORLY *****footing it with this one. As far as the cable goes, I went over that thing with a fine tooth comb probably 50 times and the pedal does open the carb all the way. My only question now is, since I have adjusted the cable out a few clicks, won't it reset itself the first time I go WOT?
