Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New Alternator = Battery Drain
Old 08-02-2005, 01:59 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Easy solution
Doc here,
Did it do this BEFORE you changed the charging system?
Quick and dirty Solution, Charge the battery up with a Charger, 10 amps 6 to 8 hours..Get a load test..If it passes,
Take it home, unplug ALL the alternator Wires and let it sit an equal amount of time, If it IS not dead, replace the Alternator..you have an OBF on the diode Pack forward biasing, and causing a load just sitting...
If It IS dead, do the load test on individual circuits as outlined in prior post..
Doc
