new battery will not run - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2011, 12:30 PM
mnwilliams2010's Avatar
1999 Chevy Tahoe 2wd v-8 automatic 5.7L vortex.
cranks but will not run in park & neutral.
new battery,plugs & wires,air filter,pcv valve,pump relay fuse,fuel filter.
also,the amp gauge needle on the dash barely moves.
vin# 1gnec13r2xj419735
please help & thanks for any help.
Old 06-26-2011, 02:58 PM
T-bucket23's Avatar
Wiki Edits: 26
What have you done so far. Have you checked for spark and fuel pressure. Common issues are the Spider fuel injection system and the module in the distributor. You need to stop buying parts and troubleshoot the issue
Chet
Old 06-26-2011, 03:32 PM
new battery
I don't have access to a lot of tools.
Why is the needle on the amp gauge barely moving with a new battery installed? It's like something is stopping the flow of electricity.
I'm a novice but still trying to learn.
thanks again.
Suggestions for battery tray/box for a group 75 battery grobb284 Electrical 1 10-05-2009 10:28 PM
Battery Box joeford Hotrodding Basics 14 11-22-2007 02:28 PM
Battery ? dollybud Electrical 2 03-05-2004 10:38 AM
battery box stang Body - Exterior 3 01-09-2004 09:47 AM
Can a low low battery, cause car to bog? Rubberman2003 Electrical 17 08-31-2003 08:19 PM
