new brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2004, 06:17 PM
stoney 81ta's Avatar
new brake lines
installed new brake line on a 81 ta my problem is the line from the master to the rear axle is about 6inches short is there anywayto fix this or will i have to run a new line. thanks all for your replies
Old 06-05-2004, 06:34 PM
Chev283's Avatar
Last journal entry: As of about 4/2004
I assume it is a flared steel line, and if so, you should be able to add a piece of the same kind of flared steel line to extend your existing one that is too short. You can connect the two pieces with a brass coupling (flared female both ends) that is available from Ace Hardware or other brass fitting suppliers. NAPA sells the flared steel lines in various lengths from about a foot up to four feet. Check the diameter of your existing line before you purchase any additional.
If you or a friend have a tubing cutter and a double flaring tool, you can cut the new piece to the exact length and re-flare according to the instructions on the flaring kit. Make sure it is a double flare. I built my entire brake system like this on my street rod in 1975, and have never had a problem.
Do not use copper, aluminum or rubber to make up the 6 inches.
Old 06-05-2004, 08:50 PM
thanks chevy its a flared steel line wiil have to go to auto supply shop and get a coupler and line to match
