New Brake Pads On Chevy C-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2010, 01:42 PM
Looking to replace front brake pads on my 1984 Chevy C-10 pickup. Anyone have oppinions on a good brand. Organic, Semi-Metallic, Metallic,material type. All ready have new G.M. Rotors. Truck is just driven on street, Thank's
Old 01-31-2010, 03:07 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
I like Raybestos. Organic stuff is out of the question. I like the PGD52C.
Advanced Technology;Ceramic;Originally Equipped With Semi-Metallic ATD52C
Advanced Technology;Semi-Metallic;Originally Equipped With Semi-Metallic ATD52M
Professional Grade;Integrally Molded;Ceramic;Originally Equipped With Semi-Metallic PGD52C
Professional Grade;Riveted;Semi-Metallic;Originally Equipped With Semi-Metallic PGD52M
Service Grade;Semi-Metallic;Originally Equipped With Semi-Metallic SGD52M
Old 01-31-2010, 03:42 PM
sqzbox's Avatar
My pipes are my music
The ceramic's would be better used with HP cross drilled rotors to disipate excess heat. They work real good and almost seem to get better when they get hot with less fade but they really heat up a standard rotor not to mention the wheel bearings.
Old 01-31-2010, 04:01 PM
T-bucket23's Avatar
Wiki Edits: 26
You cant go wrong with Wagner thermo quiets. I think they are the best aftermarket pads.
Drilled rotor are a waste of money for a street driven vehicle. The biggest benifit to them is they dissapate surface gas n continual hard breaking but you actually loose braking surface. The holes do little for cooling. The vents between teh surfaces do most of the cooling
Chet
Old 01-31-2010, 09:50 PM
sbchevfreak's Avatar
Licenced Automotive Technician
X2 on the wagners. The thermoquiets are good pads, and the SX line is good, as well, especially if you run loaded.
Old 02-01-2010, 07:39 AM
sqzbox's Avatar
The reason I tried ceramic's was to get rid of the brake pad dust on my wheels. It did a good job of that. Soo.... how does the wagners do?
I hate that crap all over my rims!!!!!!!
Old 02-01-2010, 07:51 AM
T-bucket23's Avatar
Wiki Edits: 26
They are ok, not like the cheapos. They have a good pedal feel, they are quiet and have decent life. They are not cheap, but if you do the job correctly they will last a long time. We have tried a lot of different pads and with the exception of OEM I feel they are the best. You cant beat OEM's, especially on the Japanese cars.
Chet
Old 02-01-2010, 11:32 AM
SUX 2BU's Avatar
I put Raybestos metallics on our 04 Grand Caravan. They wouldn't stop squealing when applying the brakes! Switched to ceramics and all is well. When cold they might grind/vibrate a little sometimes but once warmed up are fine.
Old 02-02-2010, 06:22 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I've had very good service and service life out of Morse Ultra pads as well, and they are considerably less expensive than the Wagner Thermoquiets. The Wagners are a very good pad though.
Old 05-13-2011, 08:37 PM
i'm going to change the brake pads on my friends Mercedes-Benz and i'm wondering if there's any special tools that will be needed to do the job and is it any different then doing a regular set of brakes on any other car with disc brakes...
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
1955 chevy with a 75 GMC IFS disc brake help h0trod389 Suspension - Brakes - Steering 2 01-08-2009 03:58 PM
brake trouble 91 chevy 1500 alabamasho Suspension - Brakes - Steering 6 08-10-2008 05:05 PM
53 chevy emergency brake 53 Chevy Bel Air General Rodding Tech 4 08-22-2007 08:08 PM
10 bolt to 14 bolt rear-end conversion in 96 1/2 ton chevy 4X4??? tommytempest Transmission - Rearend 14 05-09-2007 08:19 PM
