new build - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2010, 12:46 PM
new build
hello I'm new to the car building game. I'm having a problem with low end power. i have to play with the gas before I can move,if I slam the gas pedal to the floor it just dies. top end it flyes down the road.
73 monte carlo
2 bolt 350 bore .060
th350 w 2000-2500 stall
holley 750
edelbrock ram air intake
461x heads
msd 6a w/8.5 wires
480/480 comp cam
roller rockers 1.5
any help out there thanks
Old 10-18-2010, 01:31 PM
327NUT's Avatar
Probably have 2.73's or thereabouts in the rear end, check it and see. If so, install a 3.50 -3.73 ring and pinion and you'll see a MAJOR difference in acceleration....that is if your engine is built and tuned properly.
Old 10-18-2010, 01:34 PM
ok i will check as soon as i get home. thanks
Old 10-18-2010, 08:02 PM
bigdog7373's Avatar
Of course it's fast
Check these 2 things: Timing, and see if accelerator pump is working alright.
Old 10-18-2010, 08:44 PM
Onefunponcho's Avatar
carb?
Is the Holley a vac sec or double pump. This may be part the issue
Old 10-19-2010, 06:26 AM
the holley carb is a sec vac
Old 10-19-2010, 09:27 AM
SSedan64's Avatar
73 monte carlo
holley 750
461x heads
msd 6a w/8.5 wires
480/480 comp cam
roller rockers 1.5
As Bigdog7373 said check Acc. pump.
Vac. secondary spring may be too weak.
Check timing advance, if that's the Comp 280H cam, 16*-18* degrees Initial/Base timing, 36*-38* Total timing = 16-18 Initial + 18-20 Mechanical timing.
Converter may need slightly more stall, around 3000rpm.
Change rear gears. 3.42 & up.
Old 10-19-2010, 10:55 AM
carb issue
I would quess its a accelerator pump that is not working properly. But being that you mentioned it was a vacuum secondary holley the secondaries could be opening to quickly as well.
Buy yourself a secondary spring kit and try to slow down how quickly the secondaries open. And see how that works. If you have highway gears the stock spring is likely to quick.
But most important- ensure that the accelerator pump is working. Cause that would explain the off idle stumble.
Old 10-19-2010, 12:52 PM
I have tried a few things, its all most there. Thanks alot for the help. Right now I have 66 jets in the carb. Would that be another thing I need to change to 69 and 72. And going with a heavy spring since its a heavy car, i have the siver spring in it now.
Planning 434 build for mud drag s10, need help plutonium233 Engine 21 08-06-2010 11:27 PM
540 BBC build Biscuit6447 Engine 57 04-15-2010 08:47 PM
383 build looking for opinions 48Frankin Engine 13 03-08-2010 06:08 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
