I have checked for wiped lobes and the cam is fine and all rockers were tight so that indicates no loose studs and I didn't notice and bent pushrods it does the same thing in neutral it will rev to 4800-5 and then stop no banging no rev limit sound just stop and then if I hold it then it will actually go back down the fuel system is a 255gph pump I bought the better pump with the kit 62lbs injectors with -8 feed line -6 return
