Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New build oil consumption???
Old 06-03-2011, 11:08 PM
FmrStrtracer FmrStrtracer is offline
Youre correct, the oil consumption is excessive. Time for a leakdown and compression test. Locate the offending cylinder(s) and go from there. If you havent already,Check your valve seals to make sure theres been no damage.
