Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New build oil consumption???
Old 06-04-2011, 01:01 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Over the years I've seen high oil consumption in new motors. Usually a non piston/ring/bore problem. Usually an intake leaking on the bottom side. Improper PVC system or a rubber seal failed. Run some common tests.
