New build oil consumption??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-04-2011, 03:34 PM
engineczar's Avatar
Take a peek at the valve seals again. Is it possible that the clearance between the seal and retainer was not enough for the cam you're running and they've been damaged.
BSE Racing Engines
  #17 (permalink)
Old 06-04-2011, 04:44 PM
CJ_1080's Avatar
known to do dumb stuff!!
OK guys I was thinking a bout this....I am using a Moroso 7 quart oil pan, a standard volume pump with a 70 psi spring. I am using the factory dipstick. With a longer rotating assembly could the crank be dipping into the oil and coating the walls to much? I don't know if this would cause an overabundance of oil that can't be scraped off? I don't know, just spitballing here!
  #18 (permalink)
Old 06-04-2011, 06:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Second compression ring(s) installed upside down.
  #19 (permalink)
Old 06-04-2011, 06:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The idea of a deep oil pan is to lower the oil away from the rotator, not to add extra oil. Too high oil levels can cause excessive windage and can overwhelm the oil control ring's ability to remove the excess oil from the cylinder walls.
  #20 (permalink)
Old 06-04-2011, 07:48 PM
CJ_1080's Avatar
I guess that may be it...I've been filling it up to the mark on the factory dipstick. Maybe I will try to put less in there. That would be easier to try first, than to pull it all apart to check the rings. I am pretty positive I got them all on the pistons right! Not to diminish anyone's suggestions, you have all been a big help.
Someone told me I couldn't run my pistons on the street, due to the pin intersecting the oil control rings. Is there any truth to this? But that same person also said 1/16 1/16 3/16 rings are race only and wont work on the street. If that is so how does the factory vortec engines with their smaller rings go 300,000 plus miles?
Maybe I will give her an oil change early and see what happens! I will definately let you know of the outcome!
I am still open to suggestions, just want to try some simpler things first!
  #21 (permalink)
Old 06-04-2011, 11:20 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Pistons that have their pins intersect the oil ring generally use a support rail for the scraper to ride on.
If you want to try lowering the oil level first (I would, too), just drain whatever amount out that is in excess of 4 quarts, i.e. leave 4 quarts in the pan plus what's in the filter and that's plenty to see if it makes a difference.
To do this, the oil pick up needs to be the correct height off the floor of the oil pan- about 3/8". Hopefully you bought the matching PU for the pan you bought. That way it'll be correct.
Good luck.
  #22 (permalink)
Old 06-05-2011, 09:30 AM
CJ_1080's Avatar
I bought a oil pan pump and pickup as an oiling kit from summit. The pan was a baffled and had a trap door. The pump and pickup were allready mated and had a bracket to retain the pickup to the pump. The pickup measured right about 3/8 odd the bottom of the pan. I also reused the factory windage tray. It had to be clearances with a ball peek hammer to clear a couple rod sets. Hopefully just filling with less oil and getting the oil level away from the rotating assembly will fix it!
Do I need an aftermarket dipstick? Another thing I never considered when lengthening the rotating assembly and aftermarket oil pan.
  #23 (permalink)
Old 06-05-2011, 10:01 AM
C J I sent you a pm
dave
  #24 (permalink)
Old 06-05-2011, 10:35 AM
thin rings on the street?
Your 1/16", 1/16", 3/16" rings are LOW tension rings. That is why those pistons should not be used on the street. Low silicon forged pistons that use thin low tension rings are for racing only. Keeping the cylinder walls free of oil by dropping the oil level in a high capacity oil pan will help prevent excessive oil consumption when using low tension rings on a race engine.
  #25 (permalink)
Old 06-05-2011, 11:14 AM
CJ_1080's Avatar
I looked them up again on www.summitracing.com and summit has the rings listed as standard tension. Is this a mis-print? I was hoping they were standard tension.
Edit: the part number for the rings are; HRC 486040005
  #26 (permalink)
Old 06-05-2011, 11:29 AM
Oil ring tension
Most ring sets have standard tension OIL rings as you saw in the Summit specificatons. However, the 1/16" top and 1/16" second rings are low tension rings for racing and do not have as good oil control as standard tension rings. Radial pressure of standard tension rings are 180 - 240 PSI and low tension rings are 90 - 160 PSI.
Comparing the thin modern metric rings is like comparing apples to oranges. Those rings are designed for reduced emissions and fuel economy. They have a smaller radial thickness than the old school rings and have better conformability to cylinder wall irregularities.
  #27 (permalink)
Old 06-05-2011, 11:58 AM
Are the rings chrome if so drain the rad. and start the motor and let it run till it gets hot and I mean hot then let it cool off on its own that sould do it
  #28 (permalink)
Old 06-05-2011, 12:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There's no way to say a ring will have "X" tension because it is "Z" width.
The width of your rings has very little to do w/what the tension is. It DOES have to do w/how much friction they create. Instead it is the radial thickness (i.e. "front to back") that has a much larger effect on the tension potential of the ring, along w/the actual ring type/design.
No need to believe ME, either- do a search for yourself and see what the real world says on the subject. Perhaps one of the machinists here could lend a hand on this.
  #29 (permalink)
Old 06-05-2011, 12:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
See what the result of not filling the pan quite so high has. But as far as the "upside down second ring goes, it only takes ONE ring on ONE piston to screw the pooch on oil consumption.
An aftermarket longer dip stick could be used, or just a longer dip stick from where ever. Mark the stick as you fill the pan w/the levels when you have 3 quarts in, then 4, etc. Many vans had sticks like 4' long, Find what you need in the junk yard, unless you need it to be billet or chrome.
oil consumption 2old2fast Engine 9 04-26-2016 04:37 PM
454 oil consumption turchiac Engine 20 05-03-2010 07:58 PM
Paint consumption? brandonA. Body - Exterior 12 12-09-2009 05:34 AM
Gas consumption stoney 81ta Engine 6 08-17-2008 11:38 AM
oil consumption 4doorjoe Engine 10 07-04-2005 06:20 PM
