426 hemi with factory forged slugs would use a quart about the same time as
yours does,your piston have different elements in them to handle thermal expansion due to heat and are a tough piston to beat ,my 446 Mopar had forged slugs TRW and it used oil with plasm moly rings with special hone job they get noisy also like rattle ,but nitrous was no problem for them.I say you went the wise direction for durability.Does this help |
I've used forged pistons in my last six builds in two years, all over 450 hp, two 8-71 blower 383's, using both moly and cast rings, gapless and file to fit, with no excessive oil consumption or blow by.
Curious what your end gaps and piston to wall clearances are.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Youre correct, the oil consumption is excessive. Time for a leakdown and compression test. Locate the offending cylinder(s) and go from there. If you havent already,Check your valve seals to make sure theres been no damage.
Excessive Oil Consumption
What is the clearance on you piston to bore fit? What is you piston ring end gap? What grit hone was used to hone your cylinders? Did you double check the machine shops work yourself. It's a good idea to just to double check their work out. That much oil sounds like the rings to me. Does she smoke oil colored (bluish colored)? Leakdown test would be a good starting point. If you didn't hone the cylinders yourself, find out what grit they were honed with. Sounds like might have been too course to seat rings good.
Valve seals Are you running a complete PCV system and does the vlave covers have baffles in them? Intake gaskets? |
oil
We had this sort of problem once. It was on a 355 build. We took the engine apart 5 times changed rings, changed heads and it never corrected. What our problem turned out to be was that $5 PVC rubber grommet. The PVC area of the valve covers did not have a baffle inside the cover where the PVC valve went and the cove just had a simple round open grommet. The PVC valve was sucking up all the oil. A simple $5 cone shaped PVC grommet fixed the problem.
might want to consider intake gskt's , after you run comp. & leakdwn test's confirming no problems there....as an aside, neither of those test's will tell you if you put your 2nd rings in upside down. just some thought's ...
dave |
Check Your Machine Shop Work Out
This is turning into quite a bunch of oil consuming "ifs". One thing that I can say, no matter what, check your machine shops work out before you assemble things. They make mistakes sometimes. Tell them the cleances you want things to be, number you parts and where they go, tell them what grit you want your cyliders honed with (consult ring mfg sheet)....and double check their work. If you don't know how or don't have the mics, get somebody else to do it for you. Very important.
Over the years I've seen high oil consumption in new motors. Usually a non piston/ring/bore problem. Usually an intake leaking on the bottom side. Improper PVC system or a rubber seal failed. Run some common tests.
Does Your Valve Covers Have Baffles
The post about the PVC system. If your valve covers don't have baffles in them, that could cause your problem too. How about some feed back from the guy that posted this as to what you've tried so far. If you find it be sure and let us know. Just out of curiosity, what brand of gaskets did you use and what kind of gasket sealer. Felpro and Permatex Ulta Blue is all I'll use on an engine.
But if the goobers who honed your block thought that "moly rings" meant "chrome rings" as in chrome moly ![]() (this gets screwed up more times than I care to recount), the finish for a chrome ring would have been much too aggressive for the plasma moly rings and the rings may well have been permanently damaged as a result.
Ref To Colbalt327 Post
Amen to that Cobalt! The only engine that I ever had that the rings did not seat on was an engine that I put chrome rings in.
OK guys thanks for the responses, this is why I love this place!! I'm going to try to answer all the questions.
The piston to wall clearance is. 004. The ring gaps were 1st ring. 018, 2nd ring was .020. The oil ring expanders weren't overlapped. They were spaced out according to SRP's instructions. The oil support ring was installed correctly as well. The machine shop honed the block with a deck plate but I am unsure of the hone grit. The rings were standard tension. I am using the factory vortec injection with the factory pcv system. The valve covers are also baffled, they are factory. The gaskets are felpro problem solver gaskets, the steel shim with the rubber seal overlay, installed dry. All the gaskets I used were felpro except the Mr. Gasket head gaskets. I did a leakdown and a compression test. The compression test (sort of useless here) was within 6psi of eachother. The leakdown test showed less than 10% leakdown. My leakdown gauge reads 0-100% by 10% in increments. Runs good and idles smooth. I don't think its cause of a vacuum leak cause it wouldn't run as smooth as it does, right? This one has me stumped! Any other ideas or info needed? Last edited by CJ_1080; 06-04-2011 at 03:29 PM. |
| 454 oil consumption | turchiac | Engine | 20 | 05-03-2010 07:58 PM |
| oil consumption | 2old2fast | Engine | 8 | 12-19-2009 04:11 PM |
| Paint consumption? | brandonA. | Body - Exterior | 12 | 12-09-2009 05:34 AM |
| Gas consumption | stoney 81ta | Engine | 7 | 08-17-2008 02:45 PM |
| oil consumption | 4doorjoe | Engine | 10 | 07-04-2005 06:20 PM |
