New built 385 SBC Dieseling - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-11-2012, 10:11 PM
Did you go to college in the Xenia area. A coworker runs at Kilkare
  #32 (permalink)
Old 07-11-2012, 10:24 PM
Run on root cause is alway caused by high cylinder temperature, the gas is igniting after the ignition is shut off. It can shatter pistons.
General
to high compression
to low octane fuel
to lean fuel/air mixture
cooling system not properly cooling
timing retarded
wrong heat range spark plugs
carbon on piston tops
Hope this helps
  #33 (permalink)
Old 07-12-2012, 01:04 AM
vinniekq2's Avatar
run on
Some people I know wire in an idle stop solenoid.I run a big roller and idle the car at 950.If Im idling for a longtime I blip the throttle,of course thats for oiling,lol.
My initial timing 26 degrees and 34 total,so far my car shuts off cleanly.
Sounds like a fun car,enjoy working out the bugs and good luck.
Dieseling rtyauch301 Engine 20 12-14-2009 07:36 PM
Dieseling ?sometimes? wretched ratchet Engine 8 03-16-2008 02:59 PM
Dieseling help! cutsupreme Engine 36 10-13-2004 05:03 PM
Dieseling on new 350 70chevyc10 Engine 9 09-29-2004 11:09 PM
Car is Dieseling trick66 Engine 1 03-29-2003 12:39 AM
