We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-09-2003, 09:50 AM
CombatWombat CombatWombat is offline
Post New cam
I put a crane energizer 272H cam in my 350 from a 74 nova. The only valvetrain mods are the cam, lifters, and new timing chain. I dont need different valvesprings or anything, do I? The gross lift is .454 .
Old 02-09-2003, 09:55 AM
DoubleVision's Avatar
DoubleVision DoubleVision is online now
2nd Gunman On The Grassy Knoll
Post
Depending on the miliage of yours, are they stock? if so I`d recommend new ones that match your cam, back to back dyno tests from stock springs to correct ones showed a 33 horse power increase past 3500 rpm. I`ve run big cams without changing springs and got away with it for a while, until i broke a spring. I added new springs matched to my cam and the increase in power was real noticeable.
Old 02-09-2003, 10:07 AM
BOBCRMAN@aol.com BOBCRMAN@aol.com is online now
Post
your stock springs are good up to about .470", but if you have a lot of miles on them, replace with Z-28 replacement springs, they are cheap insurance.
Old 02-09-2003, 01:34 PM
Post
there is 84000 miles on the engine and through the disassembly it has all looked very good, and the lift is under .470 so I can probably stay with the stock ones, but how much would new ones cost?
Old 02-09-2003, 02:14 PM
78 monte 78 monte is offline
E.T. divided by $ spent= Speed
Post
I think I payed $50 installed on the heads.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
