New Cam Advice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-08-2007, 10:54 AM
firestone's Avatar
http://teamrfc.gospelcom.net
It seems to me that your heads and cam are matched OK right now. Your cam could be bigger, but I dont think it is out of the ballpark. The compression is a little low for the current cam you have though, so I think the fact that you did not go any bigger on the cam is a good thing. Being that your heads are as large as they are, I dont know that going with a smaller cam would gain you the low end power you are looking for. I think you would be better off buying a 3500 converter to get the stall speed more into the powerband when you hit the gas. When you sell the cam and heads, you could also sell the converter with them.
Adam
  #17 (permalink)
Old 01-08-2007, 12:51 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by 454C10
I think you got that back-wards. A split duration cam typically makes an engine run rougher due to more overlap.
For example a 270/270 degree cam ground on 110 lobe separation will have 50 degrees of overlap. A 270/280 cam cam ground or 110 lobe separation will have 55 degrees of overlap.
As to your split duration comment. It depends on if the intake is less, or the exhaust is more than the comparison cam. He is considering splitting to a shorter intake, thereby reducing the overlap minimally.
My poor choice of wording.
I should have said
"I think it would be a waste of money to change. You already have an outrageously large set of heads and cam for your cubes/compression.
..... If you were to use more cam the dynamic compression and the overall combination would be worse. You compression likes a 224-230* cam. Crutching the combination with a minimumly smaller cam would be disappointing in my opinion. Not much will help the slow port velocity of those large heads that like 7000 rpm on a 355 cube.
Luckily you have a dual plane intake which crutches the cam overlap. If you had a single plane intake it would be rough idle and be horrible to drive. YOu would drop 4" idle vacuum. You probably also have very large headers.
The heads and cam might be matched to each other, but not matched to the intake and cubic inches as the heads/cam implies a race car.
I would go for a maximum chassis dyno tune-up to see what you can get from what you already have, and then carefully consider changes. In my opinion your combination is ill chosen.
I would look to cam timing, ignition curve, and fuel mixture as already suggested by this forum crew.
Trouble is, chassis dyno time will eat your money and might net you minimal gains.
  #18 (permalink)
Old 01-08-2007, 01:07 PM
xntrik's Avatar
Originally Posted by Guy Hiltz
If you are looking for long term longevity you might want to shy away from an off the shelf street series Comp solid roller cam,turns out they arent made from billet steel as I had thought they were, but are made from an austempered ductile iron which has a hardened surface that can wear.If it has an 8 as the last part number this is what it is.I went from an older Crane solid roller to the XR280R Comp grind and was a bit dissapointed,it lost on the bottom end,had a bit more on the top end,but sure didnt feel as good.I`m going to be changing cams next rebuild and I dont think I will be using another Comp Cams product.
Just curious here. Not being a smart-a..s.
If you chose a ductile iron cam OR if you chose a grind that did not perform as you hoped, is either a fault of CompCams..?????
All engines are combinations and some parts work together better than others. Often minimal spec changes are quite noticable.
Did you try altering the lifter clearances to see if the cam is too big or too small for your combination? Did you alter cam timing to adjust for variations in combination? Often cam changes need fuel mixture and timing tweaking.
  #19 (permalink)
Old 01-08-2007, 03:33 PM
Thanks all for you comments and advice.......
I will take your advice and not go with a bigger cam but instead continue to save my money for some AFR 190's....I took some ill advice from the guy at the speed shop he talked me into the Dart pro1 215's as soon as I drove the car I new I had made a mistake...The are nice heads but as you guys said not enough cubes.....I will save them for another build.
Also i did call that guy Joe Sherman...He would not give me the time of day unless i was going to buy a engine from him..He was real jerk...
  #20 (permalink)
Old 01-09-2007, 12:23 PM
xntrik's Avatar
Interesting. Every time I have talked to Joe he has been the nicest person and wanted to visit about our hot rodding experience beyond my technical inquiry. I have never done $ 1 worth of business with him.
Maybe somebody was kicking his cat.
  #21 (permalink)
Old 01-09-2007, 02:26 PM
johnsongrass1's Avatar
Race it, Don't rice it!
A Dart 180 would suffice.
You could sell those heads for 5 to 800 around here.
  #22 (permalink)
Old 01-09-2007, 03:21 PM
xntrik's Avatar
Agree.
Rule of thumb on SBC is cubes x 50 % = port volume for street performance.
cubes x 55 % = volume for high rpm useage.
You want the port air velocity at an rpm range you can use effectively.
Several tests have shown that AFRs flow better for the port size. = more power.
  #23 (permalink)
Old 01-09-2007, 05:32 PM
71C10's Avatar
U.S. Army Retired
[/QUOTE]I will take your advice and not go with a bigger cam[/QUOTE]
Both cams listed in your first post are smaller then your current cam...
[/QUOTE]but instead continue to save my money for some AFR 190's....I took some ill advice from the guy at the speed shop he talked me into the Dart pro1 215's as soon as I drove the car I new I had made a mistake...The are nice heads but as you guys said not enough cubes.....I will save them for another build.[/QUOTE]
Maybe spend the AFR head money on a .060 over crank kit for your block and stroke it to better fit your Dart 215's! That would give you a 388 with a 3.750 crank or a 401 with a 3.875 crank.
[/QUOTE]Also i did call that guy Joe Sherman...He would not give me the time of day unless i was going to buy a engine from him..He was real jerk... [/QUOTE]
I don't know what to say except it doesn't reflect my experience and I've never purchased a complete engine from him, but I have purchased parts.
Did you buy the 64cc or 72cc combustion chamber Dart 215's and did you have them milled? What are the specs for your pistons?
If you replace your heads with a pair that has smaller intake runners, you still don't have enough converter (or gear in my opinion) for your current cam.
  #24 (permalink)
Old 01-10-2007, 11:14 AM
heads cam and converter
if you decide to sell your existing Dart215 heads, and converter drop me an e-mail rednekgeneral69@hotmail.com.
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
flattened cam 383vette Engine 7 05-04-2004 10:02 AM
Ignition and engine advice Jare Engine 2 03-09-2004 02:21 AM
opinion needed on a combo, cam advice Dubz Engine 2 02-19-2004 01:29 PM
The cam mistake is running, well, kinda! Jmark Engine 12 12-31-2003 12:49 AM
