I think you got that back-wards. A split duration cam typically makes an engine run rougher due to more overlap.
For example a 270/270 degree cam ground on 110 lobe separation will have 50 degrees of overlap. A 270/280 cam cam ground or 110 lobe separation will have 55 degrees of overlap.
