new cam with new lifters? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2011, 10:12 AM
Do I have to install a new cam in my 2.9 Ford V6 when installing new lifters?
Old 03-06-2011, 10:48 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
No.
New lifters on an old cam are fine, but NOT vice-versa.
Old 03-06-2011, 11:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Those engines are dependant on the center cam bearings for oil pressure to the lifters, so be sure you check/clean completely. If the oil clearance on these cam bearings is excessive, there can be a marked pressure loss to the upper end. Excessive oil bleed from the cam retainer can make this worse. A common "fix" for this is to install the cam retainer plate "upside down".
It is always preferred to replace the cam and lifters as a set. This is especially true on a high mileage engine. For the difference in cost, it's not worth the chance that new lifters wouldn't mate to the old cam- and if they don't, the engine will be filled w/ground up metal. Then the repair is replacing the lifters (again) AND the cam, PLUS disassembly for main/rod bearing inspection/replacement AND cleaning all the oil passages, etc. of the ground up metal.
Old 03-06-2011, 11:32 AM
LATECH's Avatar
those engine were noted for sludge. The pickup screen would plug and starve the engine enough that the lifters would start to tap. I have seen plenty that had that issue.what is the oil pressure cold, hot + hot at 2500 rpms?
Be sure to check it with a known good mechanical gauge.better know the condition before an attempted repair or you may just spin your wheels.(and spend cash you dont need to.)
What cobalt said also still applies.
cam and lifters logic-ali Engine 3 05-15-2010 01:24 AM
How do my lifters look? v8hed Engine 41 06-25-2008 05:43 PM
HYDRAULIC LIFTERS or HYDRAULIC ROLLER LIFTERS? SCHOONER Engine 1 10-26-2006 10:16 AM
Lifters Genisis81 Engine 1 03-25-2006 10:05 PM
Cam lifters novatech Engine 1 03-02-2006 07:01 AM
