Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new cam wont idle sbc
Old 05-28-2012, 06:18 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The spark timing is too retarded. Dis connect the vac adv. rev the motor while watching the timing. Set the timing at 34-36deg btdc while reving the motor high enough to max out the timing curve. 3000+ rpm It should idle at 14-16deg.
