new cam wont idle sbc - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-02-2012, 10:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by spinn
If that is the case. There are 3 symbols and they correspond directly to the matching symbol on the edge of the cams gear. Do you think you made this mistake?
Usually a O, A and R.
O/A/R ...triangle/ dot/ square...something like that.
edit-Except if you advance/ retard the timing. Then you would choose the center mark and retime to the corresponding other symbol on the cam gear.
They also make styles that are NOT marked inside and outside. Just on the outside of the cam gear, that has a coresponding symbol on the crank to follow.
Sounds like the crank gear was installed advanced. Or something, look at post #13.
Might have been nice to have added that info to THIS thread, but oh well. I'm done anyway.
  #17 (permalink)
Old 06-03-2012, 08:41 AM
hey guys...thanks for your help. I did indeed set the crank gear in the advanced position without noticing. I am fixing it now but I noticed the standard mark is pretty close to the advanced/retarded marks...meaning they all have about 2 and 1/2 teeths between mark and keyway. Hopefully this will be the difference though, right?. Also, can someone verify that on Edelbrock timing set 7800 you install dot-dot (cam 6oclock and crank 12 oclock) and then rotate crank 360 (cam 12oclock and crank 12oclock) before putting in dizzy? My friend says that's only for factory and to put it in dizzy for Edelbrock w/ dot-dot but that makes no sense to me. Thanks!
  #18 (permalink)
Old 06-03-2012, 09:59 AM
spinn's Avatar
reyes you are back on track now? The symbols for zero adv/retard are lined up?
Find TDC compression and install distributor to no1. Its been over a year honestly can not recall if the crank was turned 180 to install distributor. It was not even important. only that the dots for 0 remained aligned. Both valves were shut and the distributor was pointing to no1 pin on the cap.
  #19 (permalink)
Old 06-03-2012, 10:59 AM
hey thanks for all your help...I'll post the results once I get it all put back together. If anyone out there has trouble idling and backfiring @ idle after new cam/timing gear...check the cam/crank gear dots please. My bad...I heated the crank gear and overlooked that since I was in a hurry preventing a burning hand. I guess that 4 degree difference between the circle, triangle, and rectangle markings on the crank gear make a huge difference.
  #20 (permalink)
Old 06-04-2012, 06:09 PM
It's almost there. After fixing timing chain gears, I gassed motor to 3000rpm's and timed to 30 btcd with it disconnected. Ran good, idles around 1500rpm's so checked timing w/ vac adv connected, it was 14btdc. If I d/c vac adv it stalls out quick. It's weird...the idle speed screw is almost turned all the way out yet I can't get it to idle around 1000...if I turn it out more it then jumps to idle at 2000. I give it some gas and it idles high, then SLOWLY begins to die over 20 secs. I tried adjusting fuel/air mixture screws but no help. Faulty vac adv? Gas running lean? What do you guys think?
350 sbc ...large cam new dist wont start Dirtdolla Engine 4 05-12-2012 01:59 PM
wont idle task65 Engine 2 01-04-2012 08:56 AM
350 sbc wont idle 72ardosnova Engine 3 12-15-2011 10:34 PM
eninge wont idle 49fordp/u Engine 11 07-05-2010 07:34 PM
Mystery motor/cam- wont idle in drive-need to pick a converter somehow COCHEV Transmission - Rearend 5 11-14-2002 06:44 PM
