Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New cam/won't start
Old 05-28-2002, 07:09 PM
wrenchturner wrenchturner is offline
Post
Maybe try rotating distributor 180 degrees directly across from number one,did you time cam and crank gears dot to dot? If you dont want to move dist.to see if thats your problem you can move your plug wires starting number one at number six firing order.just a couple of Ideals hope this helps(wrenchturner)
