Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New cam/won't start
Old 05-29-2002, 06:32 PM
ftwchevy ftwchevy is offline
I tried the 180 degree rotation of the distributor. No luck. I'll get deeper into it this weekend. As I look back over the installation instructions, I lined the 2 sprockets up dot to dot, set the piston on #1 just begining the compression stroke and put the rotor pointing to #1 lead in the dist. cap. That seems odd. Why not go to TDC on #1? Anyway, thanks for your suggestions. Hopefully the cam is still good.
