new car need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2006, 08:51 AM
new car need help
ok well a couple of weeks ago i bought a 1991 chevy cavailer for $100 and theres something wrong with the tranny. ok well when the cars off u can chagnes the gears to whatever ones u want to but when the car starts up its stuck in that one gear and u cant change it. can anyone tell me whats wrong cuz ive been told its the pressure plate but i wanted to make sure before i bought it.ok well u can still drive the car. if u put it in first gear it starts rolling and starts right up and u can drive but when u come to a stop it dies. the clutch dosnt engage when u push it in. when your driveing u can sometimes pull the stick out of gear and put it into a diffrent one. and sometimes it dosnt start at all.....
Old 05-11-2006, 12:25 PM
65Stanger's Avatar
Check the water, check the oil
100$ for the car and 800$ for a tranny rebuild is still a 900$ car. My mom had an old cavalier when I was younger, worked great for a long long time.
Old 05-11-2006, 12:27 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Bad clutch master cylinder or slave cylinder. A pain to replace, but not too expensive.
Old 05-11-2006, 01:16 PM
sooooo
so its not the pressure plate thats makeing it do this?
Old 05-11-2006, 02:23 PM
Redman Racing
I think curtis is on to something here. sounds that way to me
Old 05-11-2006, 09:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
it can be any one or a group of failures with the release of the clutch / pressure plate.
That means from the clutch pedal to the pressure plate something is wrong, not letting the clutch release fully so the trans can be shifted.
Mayb a pilot bearing froze up on the shaft? Does it have a pilot bearing?
Old 05-11-2006, 09:39 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Its either something wrong with the clutch and or linkage or ..... if it has been sitting up a long time..the clutch could be stuck.
1985 LTD 302 V8 Cheap begginer project car 1stPROJECTcar Engine 5 05-27-2011 04:18 PM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 09:33 AM
Car Shows, My Car, & Modified Vs. Stock Class. M&M CUSTOM Hotrodders' Lounge 7 01-23-2006 06:51 PM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 10:54 AM
