New carb help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2009, 12:43 PM
New carb help
Hello,
I just installed a new intake and carb on my impala. After tuning up for a few days I think I'm getting it right. I have a problem. The transmission is not shifting on its own. It will shift on the column with no problems.....maybe a little hard. I have replaced the vaccum line from the tranny going into the manifold. We hooked up the kick down cable....but still will not shift.???
HELP PLEASE!!!
Old 01-29-2009, 06:49 PM
SSedan64's Avatar
Originally Posted by golfguy1982
Hello,
HELP PLEASE!!!
What type trans? TH350?
What carb did you have & switch to?
Is the Detent/Kickdown cable adjusted too tight? May have the valve stuck in downshift position.?
Old 01-29-2009, 09:25 PM
I honestly have no idea what transmission? I am brand new to American rods. It had a 2 barrel carb with a standard intake. I replaced it with a edelbrock performer 600. The transmission will shift using the column.....but not automatically. The kick down cable is linked up in a normal rest position. If the vacuum shift mechanism was stuck how would it act?? I really appreciate you taking the time to help!!!
Old 01-30-2009, 01:35 AM
What make a model car? Where did you put the vaccum line at to the carburetor? Does it shift at all automatically or does it just shift way late? Did it shift properly before you changed the carburetors?
Old 01-30-2009, 02:02 AM
maybe shift modulater on the trans is out. Had one once that wouldnt shift by itself thought trans was out, turns out it would shift but not till it was wound really really tight then it would snap into gear something to check.
Old 01-30-2009, 02:14 AM
Old 01-30-2009, 09:09 PM
My car is a 1970 chevy impala custom. The spot for the transmission vacuum to hook up is the same on the old as well as the new. I used an old "t" on the "top side of the intake" closes to the distributor. The tranny shifted great before I did this!!
Old 01-30-2009, 09:53 PM
T-bucket23's Avatar
Wiki Edits: 26
make sure the vacuum line didn't fall off the tranny end when you were moving things around. that is most likely a TH350. If the vacuum line comes off it will shift real late. This happened to my T-Bucket once and it was the transmission end that was off. A TH350 will work with out the kick-down, if you want to disconnect it to test. It will just shift early and obviously wont kick down.
What is your vacuum reading at idle, maybe you have a vacuum leak somewhere. How does it run other than the tranny issue.
just a side note, it is recommended that the transmission vacuum line not be tee'd with anything else. I don't think it is your issue but it is best practices
Chet
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 03:23 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 07:04 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 10:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 04:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 03:38 PM
