Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-18-2008, 02:13 PM
curtg21's Avatar
curtg21 curtg21 is offline
Bracket racer
New combo, what will it run?
My new motor is done and broke in. Just waiting on a fuel pump to due some dyno tuning. First race will be in two weeks and I'm curious what you guys think it will run.
1973 Camaro LT
350 .060over
4340 forged crank 3.48 stroke
forged 6" I-beam rods
forged Probe domed pistons
New 200cc Sportsman II's with 72cc chambers
around 10.5 to 10-3/4to1 cr
294s comp cam w/ 1.6 HS roller rockers
solid flat tappet
tall vic jr intake w/1"spacer
750cfm Holley dp hp
Dynatech stepped headers 1-5/8" to 1-3/4"
2.5" exhaust w/x-pipe and pypes race pros
th350 w/ Vigilante converter that flashes to 4000k
3.73gears w/ 26" MT DR's
around 3500lbs with driver
Car ran a best of 1.65 60', 12.11 at 110 with old 355, '993 iron heads and.230 dur at .050 with .512 lift hydraulic Ft.
Old 01-21-2008, 04:21 PM
curtg21's Avatar
Bracket racer
re: New combo, lets bench race.
Anybody? 18 views no guesses.
Old 01-21-2008, 05:35 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Because this is more of a ENGINE type question ... and there has been quite a few views here in General Rodding Tech without reply I am going to move this to the ENGINE forum.
Deuce ... Moderator
Old 01-21-2008, 07:23 PM
curtg21's Avatar
Bracket racer
Thanks, Duece!
Old 01-23-2008, 09:30 PM
curtg21's Avatar
Bracket racer
Come on guys! Nobody drag races around here? What about the engine, should I have chosen a different cam? Let me here the good and bad.
Old 01-23-2008, 09:40 PM
Chevrolet4x4s Chevrolet4x4s is offline
 Chevrolet4x4s's barnstar
get me the compression and lift,and valve size and elevation and ill run a simulation for you
Shane
Old 01-24-2008, 06:52 AM
curtg21's Avatar
Bracket racer
cr 10.5-1, 2.020'' Int/1.600'' Exh Valves,
DURATION@.050” 248, VALVE LIFT W/1.6 ROCKER .560, LSA 110°
Actual elevation is around 10' but the usual DA in the summer is between 3000' and 3500'.
Old 01-24-2008, 07:02 AM
6426yy's Avatar
6426yy 6426yy is offline
I don't have any input but I'm curious as to what your new time will be. Do you have the suspension to plant the new found power. Must be nice in Florida. It's currently -6 here.
Old 01-24-2008, 07:14 AM
curtg21's Avatar
Bracket racer
Yep, Qa-1 12-way coilovers in front, sfc, slide-a-links, 3way shocks in rear, and MT DR's.
Its 72 today.
Old 01-25-2008, 12:59 PM
curtg21's Avatar
Bracket racer
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "New combo, lets bench race."
PROFORM Race Series Carbs Shawn Horan Engine 5 09-05-2005 10:52 AM
my 350 engine combo questions mcmike Engine 7 01-16-2004 11:00 AM
3/4 race cam 78 monte Engine 8 11-20-2002 10:35 AM
Street Race Archives NAIRB Engine 5 09-24-2002 05:45 PM
which engine combo? 86SSman Engine 6 03-05-2002 05:22 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
