New compressor, need regulator... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2005, 09:03 PM
S10xGN's Avatar
Gotta love a turbo!
Hi all,
Just received my new Northern 7.5 HP, 29 cfm compressor today, this thing is huge! It puts out 175 PSI, but the only reducing regulator/filters I can find are rated to 125 PSI max. What are all the (real) garages using? I'm planning on splitting the output: 100 PSI to my bench via the regulator and full pressure to my hose reel with 3/8" hose.
Thanks!
Russ
Old 03-08-2005, 09:35 PM
4 Jaw Chuck's Avatar
Run the compressor at 125 psi.
— Han Solo
Old 03-09-2005, 06:52 AM
cboy's Avatar
Last journal entry: Finished
4 Jaw,
But how do you change the output of the compressor when there is no regulator or control valve on it? My Porter Cable also shuts off at 175 psi and I don't see any way on the machine or in the manual how to alter that. My regulator is rated at 150 PSI and I'm just running it that way for the time being and hoping I don't do any damage to anything.
Dewey
Always learning...and sharing what I've learned.
Old 03-09-2005, 09:30 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Adjust the pressure switch on the compressor...It is what tells the compressor to turn on and shut off.
Looks something like this.
Later,
WEIMER
Old 03-09-2005, 11:58 AM
cboy's Avatar
Yup, got one of those. I'll have to go inspect the innerds.
Old 03-09-2005, 05:16 PM
S10xGN's Avatar
Gotta love a turbo!
Page 3 of my compressor manual:
10.) Pressure switch - ...NEVER attempt to adjust the pressure switch. Tampering with the switch will void ALL warranties.
Oh well, I guess I own it for sure now! Had a h#ll of time though, it's a tamper-proof torx adjuster that was somewhere between a 15 and a 20. I got it to move enough to end up with 150 off. I may try taking the screw out and replacing it with an allen head.
Russ
Old 03-09-2005, 05:40 PM
Be very careful as the adjustment range may not allow what you need and you may need a new switch if you go that route. You would be a lot better off to find a regulator that is rated for what you need as you are defeating the advantage of your two stage compressor! You have gone the extra mile to get an excellent CFM delivery so why waste it now? A lot of people try to get by on an insufficient CFM rating and end up with problems but you have all the air you will need if you set it up right so my advice would be to get the right parts and use what you paid for to it's full advantage. Hey, a lot of guys would really envy that kind of air delivery and a regulator can't be all that hard to find.
Old 03-13-2005, 06:20 PM
roger1's Avatar
Oldred is right. NEVER mess with the pressure switch on a compressor.
If you go up, you would be past the rated max pressure of the rig.
If you go down, you would lose performance on the CFM ratings which makes no sense to do.
If you need lower pressures get an adjustable pressure valve.
Old 03-22-2005, 03:18 AM
Old enough to know better
I run my big 2-stage through a $20 Harbor Freight Filter-Regulator al the time and don't have a bit of trouble. Remember, for best effectiveness, you want your filter as far for the compressor as possible. Put it at your bench, not at the compressor. If the compressor is next to the bench, move it It will drive you crazy if you are too close. I also use a piece of flexible line to run my air intake outside and that makes a big difference in noise.
Old 03-22-2005, 06:38 AM
cboy's Avatar
Julmer,
Sounds like a good idea. Do you happen to have a pic of the flexible intake line you use and the connection to the compressor? I suppose I could experiment on my own but it always helps to see how somebody did it successfully.
Dewey
Old 03-22-2005, 04:58 PM
roger1's Avatar
Originally Posted by S10xGN
Hi all,
Thanks!
Russ
That 125 max rating is for the output side. 175 on the input side is not a problem.
new regulator, now it doesnt shut off 56f100 Electrical 5 05-31-2004 12:44 PM
voltage regulator slowride59 Electrical 2 07-02-2003 06:36 PM
Electrical Short, Possible Voltage Regulator Claude Electrical 2 06-21-2003 01:13 AM
Internal Regulator Question. horvath Electrical 7 05-01-2003 04:33 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
