new consoles old cars - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2010, 09:05 PM
Hi Everyone,
I was just wondering if anyone knew a trick to fit new consoles into a old cars, what I mean is the fittment to the floor from the bottom of the console.is it just sheet metal work or is it done under the carpet maybe with foam or something to that effect?
Thanks
Old 05-05-2010, 10:40 PM
Look into Nut-serts, (or other similar products) to secure a console to the floor. The product(s) work by drilling holes as needed, then inserting the bolt receiver, securing it with a rivet insertion-type tool.
Your console can be of your choice; wood, fiberglass, or steel, contoured to fit your floor, with tabs for your attaching bolts.
Old 05-05-2010, 11:12 PM
Thanks for the reply and I am going to look for them, but I was actually talking about filling the space from the bottom of the console to the floor.
Old 05-06-2010, 07:58 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Do you have any pictures of the bottom of the console and where you want to put it? It would really help to be able to see what you're trying to do.
Old 05-06-2010, 08:07 AM
Wiki Edits: 27
mounting brackets
some factory consoles have metal brackets attached to the floor. the console is secured to those brackets. you could modify those to fit your floor. then slip the console over it. trim the plastic to fit your floor contour. .
Old 05-08-2010, 09:12 AM
Wiki Edits: 22
That's a good point, but I think he's asking how to add something to the bottom of the console to make it fit the floor.
Old 05-08-2010, 09:26 AM
Wiki Edits: 31
that's what it sounds to me.... depending on console shape. could ither trim the console to fit, or do some fiberglass work to make it fit.. ither is going to cause the console to to need refinished..
nother way to do it, is find a simmilar vehicle to the 1 the console was removed from, and cut out the trans tunnel, and work it into the vehicle your putting it into
Old 05-09-2010, 01:12 AM
I made some cardboard templates and then built the pieces out of 16 ga steel and welded them to the trans hump they fit on the inside of the console and that filled the space once the carpet covers it you will never know. Thanks for all your replys guys.
Old 05-12-2010, 07:50 AM
Wiki Edits: 22
Good solution. You could also have covered the steel with vinyl covered panels glued in place. They could have been the same color as the original console, or a contrasting color.
Old 05-12-2010, 09:06 AM
Hwyhogg's Avatar
Last wiki edit: Electrolytic rust removal
Last journal entry: power tour
Any pics of your creation mounted in car?
Old 05-12-2010, 01:28 PM
I would love to post some pics but I dont know how im better with a welder than a computer
street legal race cars/ yes or no? skull Hotrodders' Lounge 10 06-10-2014 01:10 AM
Scratch Built Cars...(Home Made Rods) NEW INTERIORS Hotrodders' Lounge 163 04-09-2014 12:12 PM
37yrs old Too Old to Learn About Cars Tony79dr General Rodding Tech 18 01-11-2010 11:57 PM
Help Me Idendify All Of These Cars daveh Hotrodders' Lounge 15 07-01-2006 04:56 PM
1/24 model cars FoxThunder 5.0 Hotrodders' Lounge 24 04-25-2004 10:41 PM
