All cars in that era came with the sway-bar as an option. By all means, drill the holes and install the bar. They are absolutely necessary for good handling.
My '69 Nova had no sway bar from the factory. After one excursion into the low-3-digit speed range, and some serious sudden self-oscillation from the steering wheel, it got one real quick. You definitely do want the sway bar.
If the arms are tubular I'd advise against drilling them. Weld a homemade mount onto them as most tubular arms I've seen are 1,1/2 inch od then with a 1/2 inch hole could create a weak point. If you must drill tube then weld a tube into the hole for reinforcment.
Why?????
| Trust "beaten on" lower control arms or not? | TNshadetree | Suspension - Brakes - Steering | 3 | 02-21-2006 12:05 PM |
| after market control arm's | ORHotrod | Suspension - Brakes - Steering | 1 | 05-07-2005 11:14 AM |
| boxing in rear control arms "HELP" | 406 ss monte | Suspension - Brakes - Steering | 11 | 02-20-2004 12:55 AM |
| Tony - question about new control arms | 61wagonair | Suspension - Brakes - Steering | 1 | 11-19-2003 07:21 AM |
| rear lower control arms | oldsnut | Suspension - Brakes - Steering | 3 | 12-15-2001 09:01 AM |
